Welder in Phoenix
Welder in Phoenix
Postby Chuckaz » Sun Sep 11, 2011 5:14 pm
Hello fello Tear Droppers,
I have my trailer that I am going to convert to a tear drop. It was an old boat trailer so I need to remove the vee bottom supports and weld in flat bottom ones. I am going to start there because I need to use the trailer for some other things before I do the tounge shortening and tear drop building. Does anyone know a reasonably priced welder in the north Valley that you would recomend? I am going to have the cross braces already cut and ready to go to reduce the ammount of fab that the welder need to do.
Thanks
Chuck
Chuckaz
Images: 14
Postby Shadow Catcher » Sun Sep 11, 2011 8:03 pm
My suggestion is to check with the local welding supply store if no one comes up with a recommendation.
Postby asianflava » Sun Sep 11, 2011 10:43 pm
The guy who welded up my frame was my neighbor across the street from me in TX. We moved to Colorado and they moved to Scottsdale. I don't know if he has a shop there though.
asianflava
Postby TheBizMan » Mon Sep 12, 2011 9:43 am
Check on aztearjerkers.com under TDs for sale. Call Ray Permenter of Rayme trailers. He does great work and is at 19th ave and Thunderbird. Very reasonable.
Lee - TheBizMan sez
Teardrops make for happy camping
TheBizMan
Welder
Postby Redman3638 » Thu Oct 13, 2011 9:52 pm
If you still need a welder send me a PM. Im in glendale at 67 ave and Northern
Redman3638
Return to South West
