Dutch Oven DOG video
Posted:
Wed Dec 06, 2006 5:05 pm
by Ma3tt
don't know if anyone has posted this before... I didn't watch the whole thing I got hungry and had to go cook something. It is the opposite of subliminal! whatever that is.
http://tinyurl.com/y473pg
Posted:
Wed Dec 06, 2006 5:58 pm
by Steve Frederick
OH Boy!!
Guess what I'll be doing this weekend?
Posted:
Wed Dec 06, 2006 6:52 pm
by Outlaw
Thanks very much for posting this. Being the DO Newbie, I had never heard of the 3 Up/3 Down Rule. I'm glad I already had supper before I watched this.
Posted:
Wed Dec 06, 2006 8:02 pm
by TomS
Thanks for sharing the video.
Posted:
Thu Dec 07, 2006 1:59 am
by ARKPAT
Very Good video THANKS!!
I learned a lot when watching Ray at Grand Lakes now this helps also.
Great Job in my lesson in cooking with DO.
pat
Posted:
Thu Dec 07, 2006 4:13 pm
by Et Cetera
Thanks for that link!
I found this forum on Dutch Oven Gatherings if you want to find one near you.....
http://forums.idos.org/ShowForum.aspx?ForumID=13
Posted:
Fri Dec 08, 2006 12:50 pm
by Ira
EXCELLENT!
It got me thinking about getting into that, although I've been resisting.
So if it's a 12" oven, you put 15 coals on top, and 9 on the bottom? And what do you do, burn coals elsewhere and place them as needed?
Posted:
Fri Dec 08, 2006 1:49 pm
by Loader
Ira wrote:So if it's a 12" oven, you put 15 coals on top, and 9 on the bottom? And what do you do, burn coals elsewhere and place them as needed?
That's it. You use a Chimney Starter, then use as many coals as you need.
http://virtualweberbullet.com/chimney.html
Posted:
Fri Dec 08, 2006 1:54 pm
by Ma3tt
Chimney starters are for wooooosies use this
3000 degree Propane torch from harbor freight will start 50 lbs of briquets in 4 minutes and wake up the neighbors
Posted:
Fri Dec 08, 2006 2:10 pm
by bledsoe3
Ma3tt, I like the way you think!
Posted:
Fri Dec 08, 2006 3:03 pm
by Loader
Ma3tt - great idea....guess it's time to run and get the torch! Or, what about an old WWII Flame Thrower???
Posted:
Fri Dec 08, 2006 3:27 pm
by asianflava
I put my chimney starter on top of a my turkey fryer burner. I dump the coals into my BBQ pit and pick out the coals I need with a pair of tongs.
I have that same Weber chimney starter and I like it better than any of th other ones I've used. The body is better but the grill on the bottom is coming out.
