NYFD firehouse chow..
Posted: Wed Jul 20, 2005 7:57 pm
A Yummy simple recipe...
The original recipe came off a Newyork fire department calander a couple of years before
9/11.I modified it for use for sunday brunch in restraunts..60 servings..After 9/11 I returned the recipe
back for family use.So this isn't quite the original recipe..Also variations:Ham is excellent,turkey,chicken
Your favorite sausage,homemade or purchaced,meatless:broccoli works well,use your imagination w/this recipe
Make it a couple of times & you'll know what you want more of or less of...The recipe is excellent as it is though.
Great for breakfast,lunch,even as a sandwich..
1 C. hard salami..one of those 12 oz,to 1lb small summer sausage rolls works also.
1 lb carton cottage cheese
1 tsp garlic pwd
1 doz eggs use 9 save 3 for the end
1 cube buter
parmesan cheese, I put 1 tbl in the mix
3 eggs for the top before baking
Original recipe calls for 1 tsp garlic salt + 1 1tsp salt also,Im a low salt person
to me the meat ,butter,cottage cheese has enough salt.
Mix eggs good in large bowl (9) chop or dice meat into bite size pieces & add.
melted butter,not to hot!We don't want to have any eggs start to set up.
Add cottage cheese,parmesan cheese, spice's,mix well,pour mixture in non stick pan,easy to use 2 smaller pans,or 1 larger pan..whatever you have
Now mix 3 eggs well,Get a little air in them...pour them over the top,spred em around to cover,
Bake at 350 till it's golden brown 25,35 min. depending on oven..serve while hot w/more parmesan cheese.
Serve w/fresh fruit,breakfast rolls,sourdough,w/good jam is good also.just about
anything will taste Great...Ive even baked this a few times w.colman fold up oven & stove,no problems.YUMMY vinoscooter
1 tsp garlic pwd
1 cube buter
