Prime Rib Bordelaise...
Postby Dean in Eureka, CA » Mon Apr 25, 2011 7:01 pm
We had a blast at the Rustic Whitethorn Run this past weekend...
http://www.youtube.com/watch?v=4Fc7wfVa6qA
This will be our last video until we get a new camera, as it decided to buy the farm... Luck was with us as we were able to retrieve the clips for this video to share.
Enjoy!!!
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby parnold » Mon Apr 25, 2011 9:59 pm
Yet another great video!
:thumbsup: :thumbsup:
parnold
Images: 302
Postby boomer » Wed May 04, 2011 11:25 am
a work of art!!! Beautiful!!
boomer
Postby S. Heisley » Wed May 04, 2011 7:51 pm
Good job! :thumbsup:
Lodge should send you some free cast iron cookware.
After all, you're giving them plenty of free advertising. (TeeHee!)
Postby boomer » Thu May 05, 2011 8:39 am
wonder how we could adjust the cook time for a smaller roast...
boomer
cook times
Postby The Teardrop Nanny » Thu May 05, 2011 9:30 am
For a smaller PR, say 10 lbs., reduce the cooking time by about 30-45 minutes. For a cut of meat like this, a probe thermometer is the best indicator of doneness, and a laser one is even better. Keep in mind that the meat will continue to cook after removed from the heat, so if you remove it at the temp. about 5-10 degrees below your desired doneness, tent it with a foil covering, let it sit 30-50 min., it will continue to raise temp. over that time. We pull the meat about 10 degrees off, and if tent properly, and keep in a protected spot from cold winds, it will usually pop up to the medium/medium rare in that time. Enjoy and PM us when you buy one to try and we can give our recommended cooking time.
Joanie
The Teardrop Nanny
Teardrop Muse
