dutch oven seasoning
Postby Dean in Eureka, CA » Tue May 16, 2006 11:13 pm
Courtney,
I haven't braved the way of the tomato yet, but I've read that it's a good idea to coat the oven with oil just before doing stuff with tomatoes... That way the acid from the tomatoes eats at the oil instead of your seasoning.
(Makes sense to me)
I'd just add more seasoning and see if that does the trick.
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby Steve Frederick » Mon May 22, 2006 7:57 pm
TomS wrote:
If you do have to strip and reseason the entire oven, I suggest you do it outside on a gas grill. If you use your home kitchen oven, you'll smoke up the house big time.
Yup! I made that mistake! :DOH2: My wife is still a bit leary of my D/O adventures!!
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby Laredo » Mon May 22, 2006 10:35 pm
Note: the pottery kiln is NOT a good substitute. You can melt cast iron...
Laredo
Postby Kevin A » Mon May 22, 2006 10:44 pm
Laredo wrote:Note: the pottery kiln is NOT a good substitute. You can melt cast iron...
Laredo,
Are you speaking from personal experience? Just how hot does a pottery kiln get?
Kevin A
The other guy
Images: 289
Postby Laredo » Mon May 22, 2006 10:51 pm
how hot's a kiln? depends. Whatcha firin'?
But no. What I melted was, alas, a fairly nifty piece of ceramic lace.
(buy or crochet lace. Dip it in slip, let dry. Repeat, then fire. ... makes a nice contrast trim.)
Laredo
Postby PresTx82 » Wed May 31, 2006 9:32 am
I read the above threads about using tomatoes in your DO. So, the consenses here is you can cook tomatoes (stew, lasagna, etc.) in the DO, but you just got to insure it has plenty of oil in it before and after it's used?
Mark
El Paso, Texas
PresTx82
Postby Nitetimes » Wed May 31, 2006 10:50 am
PresTx82 wrote:I read the above threads about using tomatoes in your DO. So, the consenses here is you can cook tomatoes (stew, lasagna, etc.) in the DO, but you just got to insure it has plenty of oil in it before and after it's used?
My wife makes spagetti in my 14" CI skillet all the time, just rinse it out with hot water afterwords, never been a problem.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby madjack » Wed May 31, 2006 1:43 pm
...same here, I cook spaghetti sauce, chili, and other various cajun, tomato based sauces in my CI all the time...just wash and put back on stove to re-heat and wipe some oil onit...good to go
