SOLD - 2018 Weeroll Nomad conversion
Postby Iroll » Sat Jul 07, 2018 1:30 pm
For sale is a beautifully converted 2018 Weeroll Nomad used only twice for camping.
These trailers are a superior build from most cargo trailers with "shark cage" construction. Please look at the Weeroll website (http://www.weeroll.com/classic) to see how these amazing trailers are built. It will last you a lifetime!
6' x 8' x 6' (with 18" extra in the Vnose)
2" ball
2000 lbs jack
Safety Chains
Triple extended tongue with cargo carrier
3500 lbs Dexter axle
15" Radial tires plus a spare
Chrome Hub caps and lug nutz
Aluminum tread plate fenders
2" Receiver Hitch on the back for bikes, kayaks, ATVs
Stabilizer Jacks
Front stone guard
12" Diamond plate on sides and rear
Roof Vent
2 - 30 x 15 windows with screens
Double rear doors (beautifully stained on the interior)
24" locking side RV door
Insulated ceiling and walls (1" foam polyiso board)
Aluminum ceiling
Painted Birch walls
Led tail lights, running and tag lights
4 way electrical plug
15 Amp motor base plug
2- 110 volt outlet
wired for roof AC if desired
A\C door on street side (will accommodate 5000 BTU window air conditioner)
Empty weight: 1400 lbs
Build weight: 1650 lbs
Build out:
34" x 69" platform bed with space underneath for storage
8" memory foam mattress and foam eggshell topper
small cabinet street side for storage
Tall pantry for storage
Kitchen base cabinet with L-shaped countertop
Stainless bowl dropped into counter (not plumbed but you can easily do so)
Access hole in countertop for propane hose
Unique aluminum tile backsplash
Upper cabinet storage in two mounted crates
Stainless wall base mounted to side of one of the crates (I used for magnetic spices but could also be used for magnetic knife strip, cooking utensils and other multiple uses)
Two cable hatches installed behind kitchen cabinet (one for propane and one for house batteries)
Two plastic drawer units for additional storage
4 pin to 7 pin adapter
ball locks
There is room under the L-shaped counter for a refrigerator/cooler and porta-potti. It's all ready for you to add house batteries and solar with space under the countertop to mount a controller, inverter and fuse box.
All the components are held in place with a few screws so it would be easy to reconfigure, if desired.
This build was made to make maximum use of space and still allow for space to cook, dress and move around. You won't believe how spacious it feels for the size.
If you are looking for an inexpensive lightweight, easy-to-tow trailer that is comfortable and has all the basics already built out for you, this is it! Many compact SUVs can tow this trailer without a problem. Whether looking for a fun weekend camping trailer, a full-time Nomad space, hunting trailer or a trailer for Burning Man, this would be a great low-cost option. No worrying about dumping tanks, roof leaks or separating seams due to towing on washboard roads. This trailer sits high enough to handle all but the most remote locations and it will last for decades. If you want something that is quality built (unlike most RVs) and you don't have the time to build it out yourself, this trailer is ready to go for you.
$6,000 - Motivated seller willing to negotiate. Clear NV title in hand.
(Decorative items don't convey)
affordable camper, light weight camper, mini camper, cargo camper, diy camper, small tow behind camper, travel trailer, aluminum camper, burning man, cargo conversion, glamper
Iroll
Re: 2018 Weeroll Nomad conversion
Postby knova » Mon Jul 09, 2018 11:05 pm
Careful, you linked the “manage” page for craigslist. Anyone with that can edit or delete the post.
Personal website: https://www.novakeith.net
Family website: https://novaks.us
Listen to my music: https://music.knova.net
knova
Postby jmanscotch » Wed Jul 18, 2018 4:53 pm
I got his phone number from his ad and texted him, Knova.
Good catch.
Good luck with the sale sir.
Jake
jmanscotch
Return to For Sale/Wanted
