Sold Trailtop 41 derge. railing kit there to build a 6x6 10'
Postby saywhatthat » Tue Jun 02, 2020 5:18 pm
$1,108.00
WE are not the con men that posted over 7500 times that they invented this in in 2010 to get you to go to there page to get more add money. And fishing for $35.00 a running foot This been around for over 75 years in fiberglass.
For sale Trailtop fiberglass components Square profile. glue and go. 6 ea. premade 41 degree bends with 24'' of profile tail 2 ea. 90 deg. bends 45 feet of side railing with 3'' off set . Easy to make a 55'' wide trailer using 48'' plywood .Full bed.
60' free floating Cross ties 32 feet of bottom plate .
This all hand laid fiberglass No chopper gun crap. What you see on the ground NOT THE TRAILER.
The reason for sale is . I received 12 ea. 41% kits Now they have a 24'' radius profile can build more teardrop style .
Will not be building as many square tops $1,108.00 Near Mather Calf. by the drag way
What is old is now new .Infill building with fiberglass profiles has been around for over 75 years. TrailTop modular fiberglass components aim to simplify building. Time savings. Construction using of TrailTop will cut planning and construction time. Fewer tools and associated fab skills required than some other methods... i.e. welding, wood fabrication Will save time and money. You have a "system" that requires very little input to get satisfactory results. Very basic cutting/measuring glue and go. You will have the confidents to actually succeed in producing something that is structurally sound, functional, and looks "finished campers, truck shells, utility trailers, plant growth chambers dock boxes TrailTop components have been designed to be easy to modify and assemble, resulting in a strong structural framework .That is light weight .Will not rot...
Il suffit de le faire
D.I.Y Light weight sleeper using D.I.Y rail top components.
viewtopic.php?f=50&t=66751
saywhatthat
Images: 139
Re: Trailtop 41 derge. railing kit more there to build a 6x6
Postby saywhatthat » Tue Jun 02, 2020 6:59 pm
Sold Father in law will do a full skeleton frame of your design with floor for $350 and cost of flooring with clamshell pop-top add $150 Also install on your built frame
For the buyer of this kit
What the buyer wants is a shell of the weekender 5' 4'' foot wide 10 foot long on Haber freight trailer
saywhatthat
Images: 139
Return to For Sale/Wanted
