Ontario Trim & Seals
Camping in Ontario & Quebec and the Central Canadian Chapter of TearJerkers
Postby Angus McBagpipe » Sat Jul 28, 2018 6:47 am
Hi Builders,
I'm located east of Toronto and building my own TD.
I'm looking for suppliers of extruded aluminum trim and seals in the Toronto area.
Do you have any suggestions/suppliers?
Angus McBagpipe
Re: Ontario Trim & Seals
Postby jlw » Fri Jan 04, 2019 8:37 pm
I too would like to know where ontario builders are getting their supplies.
jlw
Postby Adam-is-Teardropping » Mon Jun 15, 2020 4:28 am
Posting to potentially revive this thread! I am in the process of designing a teardrop and finding trim and seals is proving quite the challenge in Ontario!
Thanks,
Postby PCO6 » Mon Jun 15, 2020 5:15 am
Amazon is a good source (example … https://www.amazon.ca/Adhesive-Automoti ... 64&sr=8-28).
I find that unless you know exactly what you're after, RV dealers aren't a lot of help and other suppliers won't let you rummage through what they have while you "design" things on the spot in your head. For the small amount you might buy it's really not worth their time.
Although this is a bad time because of the virus, I've had good luck at flea markets such as the Barrie Auto Flea Market (Burl's Creek - June & September), The Ancaster Flea Market (Fairgrounds - April) and the Motor City CC Flea Market (International Centre - December).
PCO6
Postby RunningThreads » Fri Jun 19, 2020 1:44 pm
You might try https://www.theteardroptrailer.com/ . They are trailer manufacturers near Newmarket and I know at one time they sold parts.
Nigel
RunningThreads
Return to Ontario & Quebec, Canada
