Custom required for tucked-under wheel designs?
Postby John61CT » Mon Oct 16, 2017 5:40 pm
I want a full-length bed sideways, and thick insulation, so I reckon I need a 7.5" outside box width.
I go off the pavement in the boonies, so don't want the wheels to extend outside that width.
I also need robust tires and a low COG, so a "deck over" design won't work; I am willing to have wheel wells inside the box.
Are there good quality makers that offer such a design as a standard option?
And also, if I choose to get a custom frame, could members please post recommendations?
I probably can't afford to go aluminium, but suggestions for that would also be welcome.
I'm planning to travel cross-country anyway, willing to do so to pick up the trailer, since I imagine great value for money makers would be thin on the ground in the northeast.
Thanks in advance!
John61CT
Re: Custom required for tucked-under wheel designs?
Postby jandmz » Mon Oct 16, 2017 9:48 pm
You may be able to adapt and build on a stripped down popup camper frame. Most are of the width that you would require for a side to side bed arrangement and may already have the floor and wheel wells in place. Most modern designs use a torsion axle. There are lift kits available, but an older trailer that has leaf springs may be easier to lift for larger tires. So, there are ways around it, and a custom frame may not be required.
jandmz
Postby aggie79 » Tue Oct 17, 2017 7:48 am
Is the bed fore, aft or between the wheel wells? )I'm assuming the answer is not the latter since that would result in a trailer width of 9-10'.)
Postby John61CT » Tue Oct 17, 2017 8:45 am
The recycled popup is a great tip!
Bed aft most likely, as I said, 7.5' is the max outside width I'd want. I believe 8.5' is the max legally, but even 8' is too much for me.
John61CT
Postby John61CT » Tue Oct 17, 2017 8:55 am
slowcowboy wrote:Consider the kampmaster design in the 1953 popular mechanic magazine.
Nice design, may take some layout ideas.
But mine's not going to be like a tent, want good insulation.
John61CT
