3/4 EMT Conduit Frame
Re: 3/4 EMT Conduit Frame
Postby ferbal » Thu Apr 12, 2018 6:37 pm
Ran across a forum today about building airboats down in the Everglades apparently EMT is the material of choice for many builders because of its inherent corrosion resistance and cost
ferbal
Postby John61CT » Thu Apr 12, 2018 9:50 pm
I wonder what spacing you'd need to do a drop floor for a 200lb owner, supporting say 1/4 ply + PMF done with screening. . .
John61CT
Postby Jiminsav » Sun Apr 15, 2018 10:19 am
well, what a co-winky-dink...i am planing to build a frame from 3/4 conduit and putting aluminum on it with rivits. i'll be watching this for guidance.
8)
Jim in Savannah
Jiminsav
Images: 30
Postby ferbal » Mon Apr 16, 2018 6:47 pm
If the weather cooperates I will do some welding on my frame this week. I will keep you posted on how it turns out. I figure worse case scenario it is not strong enough for the design I have in mind, then I figure I will just sleeve my 3/4 in some 1 in or 1 1/4 and call it good.
ferbal
Postby ferbal » Tue Apr 17, 2018 8:24 pm
I started my build today. I welded a 30 inch piece of 3/4 emt to my trailer. The weak spot in my design is not the emt. The open channel construction of my converted boat trailer was flexing/bending while I pulled on the emt to check its strength. So I believe that 3/4 emt should work just fine.
ferbal
