It's time for a new Generic Standy Design...
Re: It's time for a new Generic Standy Design...
Postby alchemist77 » Sat Feb 11, 2017 1:03 pm
alchemist77 wrote:I am thinking of a Winter Warrior design.
Lower profile when towing, able to expand to an 86 inch height so I can stand up and stretch. Foam build with wood ( or steel ) to reinforce the stress points. I want to put solar panels on the roof, use wood to frame the windows, make the hatch from 1 inch foam/ wood. Back- foam with wood frame, each panel individually made and fitted. Use the interior to help hold the exterior and maintain rigidity. Need more drawings and description. Let's call it "Yeti"!
Sent from my Lenovo TAB 2 A10-70F using Tapatalk
Check out, Beula in the forum's.
David Campbell
KF7SFU
RaDAR
SOTA
alchemist77
Images: 10
Postby ajshortmac » Mon Jan 01, 2018 10:39 am
mikeschn wrote:I can't do any building for a couple months, so I think it's time for a new Generic Design. Can you guys help me out with the requirements...
Why a new design? If a teardrop is not comfortable enough, you might want something larger. If you live east of the Missippi, rain happens, usually on the weekend while you are camping. If you are camping rustic, you might want to bring your own shower. And if mother nature calls in the middle of the night, you don't want to trek down to the outhouse or bathhouse. Some people are talking about camping longer than a weekend. Some of them want more than a TD. Some people want a tiny trailer to flee hurricanes etc. So with all that in mind, let's see what we as a group can come up with...
Here's a couple requirements I think we should include.
Ability to stand up inside it.
Ability to cook inside
Ability to go potty inside
Ability to take a shower inside
Ability to use a bolt together trailer
Ability to sit and eat inside
Simple construction
Lightweight
Can be towed with a medium sized car
Adequate storage
Yes, we are packing 10 pounds of RV type stuff into a 5 pound trailer, and there will have to be some tradeoffs as we proceed into the design. But hey, isn't that what makes it fun?
:roll:
So what did I miss?
I've thought the same thing. I'm going away from a traditional shape. Here's a sloppy sketch of what I'm thinking. Image
Sent from my SAMSUNG-SM-G900A using Tapatalk
ajshortmac
Postby Richrad » Fri Sep 07, 2018 12:17 am
May I suggest a drop-floor section? Get the standing height you need by lowering a fabric walled segment of the floor when parked. Much lighter than building a pop-top or taller all the time trailer. Most trailers have at least 12” underfoot.
Richrad
Images: 5
Postby Hamilton Felix » Sat Oct 06, 2018 9:05 am
Hmm.... RVs have all sorts of slide-outs these days. With a perimeter frame design and axle-less design, there's no reason you couldn't have a slide-DOWN. Park in a nice flat spot, then drop the floor to the ground. Your design would keep any wiring and plumbing in the walls, not underneath.
Life is too short not to be happy.
Hamilton Felix
Postby cameronrm » Fri Oct 19, 2018 1:52 pm
I"m new here, and very interested in what is being discussed in this thread as I'm looking to build a "standy" myself. I've been reading lots of posts in every part of the forum and have taken a real interest in foamies. However, in this particular thread I don't see any of you experienced people suggesting that foam would be a consideration for this new Generic Standy. Is there a reason for that? All I've read tells me that its an amazing building component - light weight, becomes very strong when properly skinned, good insulation qualities, etc. I'm considering a 7'x12'x6'6" tall unit that would be pretty much a "standy" made of foam. I admit I don't know very much yet, but I've got months to learn as I browse through all the posts of the many different builds on this forum.
cameronrm
Postby Train Wreck » Tue Nov 13, 2018 5:16 pm
It's in the baby stages of the build but it's a big one. Should be cool standy when I'm finished. Just mounted the floor to the trailer today. Framing walls this weekend. I'm kinda winging it.Image
Sent from my SM-G955U using Tapatalk
Train Wreck
Postby GPW » Fri Dec 07, 2018 5:29 am
Cameron , ask those questions in the Foamie section ... ;)
Postby dbhosttexas » Wed Oct 13, 2021 2:54 pm
Consider foamie construction to keep weight reasonable and insulation values high.
dbhosttexas
Images: 29
Postby cluttonfred » Thu Oct 14, 2021 4:55 am
How about a foamie version of the Wanderer 8 and 10? http://tnttt.com/Design_Library/The%20W ... d%2010.htm
dbhosttexas wrote:Consider foamie construction to keep weight reasonable and insulation values high.
Matthew Long, Editor
cluttonfred.info
A site for builders, owners and fans of Eric Clutton's FRED and other safe, simple, affordable homebuilt aircraft
« Voici ce que j'ai fait...vous pouvez en faire autant! » "This is what I have done...you can do the same!"
--Henri Mignet (1893-1965)
cluttonfred
Postby Mark Gunter » Fri Jul 07, 2023 9:17 am
My requirements didn’t include a shower or potty inside or cooking inside. They did include A/C, heating, a place to eat/use laptop and a king size bed for sleeping. Also, a good weatherproof roof fan and a 300 watt solar array. The goal is ability to camp year round and the ability to boondock comfortably.
I wanted the hatchback outdoor kitchen for my standy, similar to a teardrop, but I decided to also install a gas stove inside “just in case” we decide to heat up or cook something in inclement weather. We’ll use a potty tent and luggable loo for outdoor potty and the loo can be used inside at night for my wife’s convenience.
I'm a happy man, I love my life!
My Gunter Li’l Standy build journal:
https://www.tnttt.com/viewtopic.php?f=50&t=75291
Mark Gunter
Images: 211
Postby Buddy-and-Missus » Sat Nov 25, 2023 4:15 am
We hit most of the list with my design.
I'm a small footprint home designer but I have to say this was a challenge.
Ours should (hopefully) weigh in at about 1000lbs when complete.
I didn't like the idea of bringing the outdoors right in to the trailer when dirty after a day outdoors so I designed ours with a mudroom/bath combo, the shower is indoor/outdoor and the wet room/mudroom area where you enter is large enough for a collapsible tub.
Height is plenty tall for my 6' hubby and has a load of storage.
Our design slides into a utility trailer.
[img]
[/img]
White Blue Design Final.jpg (225.79 KiB) Viewed 2463 times
Buddy-and-Missus
Postby tony.latham » Sat Nov 25, 2023 11:14 am
Let us know when it hits the scales.
Postby KCStudly » Tue Dec 05, 2023 9:59 am
The sleeping area along the streetside wall looks extremely short. Does that bunk get made up bigger parallel to the forward crosswise bunk using a folding platform? Otherwise I can't imagine two people laying comfortably at 90 deg with their feet in the same spot. :thinking:
Postby HarryPotter69 » Sun Jan 07, 2024 9:13 am
wanta have some fun figure the snow load on this roof with about 2' of heavy wet snow on it !
HarryPotter69
