twisted lines wrote:Snow's finally gone, someplace's
I believe I have that exact same battery charger. Mine has 2 switches- either 6 or 12 VDC and either 2 or 10 amps. I've had it for around 30 years.
rjgimp wrote:I believe I have that exact same battery charger. Mine has 2 switches- either 6 or 12 VDC and either 2 or 10 amps. I've had it for around 30 years.
Tom&Shelly wrote:Welding would have been better, and if this works out, Mark II might be one of my first attempts as I learn (after buying the equipment).
bdosborn wrote:Tom&Shelly wrote:Welding would have been better, and if this works out, Mark II might be one of my first attempts as I learn (after buying the equipment).
It's tradition that the first thing you make with your new welder is a cart for your new welder.
I finished installing two Saw Whet nest boxes...
TimC wrote:The PVC design has proven to help as the Starlings won't fit and the Sparrow does not like the design for some reason.
Tom&Shelly wrote:TimC wrote:The PVC design has proven to help as the Starlings won't fit and the Sparrow does not like the design for some reason.
Sparrow's instincts tell them to "go sit in the corner"?
Tom&Shelly wrote:We have this folding portable grill
We'll see how it works. I hope the bolts stay tight with repeated heating. Welding would have been better, and if this works out, Mark II might be one of my first attempts as I learn (after buying the equipment).
