After I read your post, I immediately took a practice test online (I have absolutely no idea of any FCC rules or tech talk or radio lingo). I scored 60% (not good enough to pass), but better than I thought I=I would do. I also looked up "mobile ham radio transceivers", and found that IF I get a license, they are not much more expensive than what I spent on CBs back in the day (probably much less in comparison of pricing then and today). Still interested, especially since I found a chart of relative transmittal range of various amateur radio types:jss06 wrote:Howdy, The Technician Class test is pretty easy for a HAM license no Morse Code required. You can get some inexpensive basic 2m and 70 cm gear to get started. For a teardrop you can use a j-pole antenna as it does not need a ground plane. (Look up Copper Cactus)
I use a Kenwood TH-72A DualBand Handy Talky and an MFJ amplifier for mobile operations in the 2M/70CM bands. I can easily take it out when I go hiking or just hanging around the camp site. I have a copper J-pole for campground use.
I am still working on how to put a HF rig in the trailer. Maybee a Elecraft KX3 connected to a Rasberry Pie for digital comms and email. Will need to play with it some to keep power usage low.
Mary C wrote:I have a strange question can the FCC give out the same license if you have had it and it lapsed? Ya'l have me thinking about it again, it has been 20 years since I was licensed. If I don't watch out I will try to take the test again. If I do I will get it down all the way to Da Da dit dIt.
Mary C.
