Gentlemen,
The creeping fear is almost palpable
yes, we must seek refuge in steel.
NOT!!!!
The seismic retrofit industry in California has been dealing with the wood issues you raise for years. Square washers and mudsill plates have been the remedy of choice, in addition to epoxy. I think you guys would be interested in the following website
http://bayarearetrofit.com/RetrofitDesign/Bolting/bolting.html
Arne, a simple gusset, 6x6 triangle 1/8" thick would be much more than enough. 1/4" steel is way overkill. Might as well build a steel frame. Additionally, if one is using a torsion axle, would the heat of welding damage the rubber in the torsion axle?
The issue is not whether the torsion box is correct, but rather, whether the tongue is stiffened properly.
[/url]
