PICTURES PLEASE --- GALLEY HINGE ENDS THE RIGHT WAY
Postby mikeschn » Thu Apr 14, 2005 8:23 am
Denny Unfried wrote:I also put a four wire trailer plug on the hatch that can be unplugged. Then the hatch can be easily be slid off to remove and clean any sand or grit that might get into the channel. It was removed several times during the build to install the electrical et cetera and it works great. Denny
We did that on the Baja Benroy and it worked great. I think I'd like that on the Lil Diner too!
Images: 479
Postby bdosborn » Thu Apr 14, 2005 2:02 pm
Denny Unfried wrote:I also put a four wire trailer plug on the hatch that can be unplugged. Then the hatch can be easily be slid off to remove and clean any sand or grit that might get into the channel. It was removed several times during the build to install the electrical et cetera and it works great. Haven't had remove since finished but I haven't been in any blowing sand - yet.
Denny
Hey! That's a great idea! Thanks Denny and Mike. :thumbsup:
Images: 777
Postby TonyCooper » Thu Apr 14, 2005 3:30 pm
I believe this is how Kuffel Creek recommends doing it. I grabbed this pic off of a tear build site and would give credit if I knew whose it was. Anyway, this is how I'm doing mine.
My Tear Build Site
"No comment"
TonyCooper
Official Pot Stirrer
Images: 35
Water Diverter
Postby OkieSailor » Thu Apr 14, 2005 6:54 pm
The water diverter looks great, but where can you get one. I could hand make one but it would be a pain. PS thanks for all of the great answers and photos. I am fixing to put my hinge on when I get it and welcomed all of the information.
Yes OkieSailor is an Oxymoron!!
OkieSailor
Postby mikeschn » Thu Apr 14, 2005 6:59 pm
No pain, no gain... plan on making it from scratch... ;)
Images: 479
Pain
Postby OkieSailor » Fri Apr 15, 2005 9:30 pm
Yea! like I'm going to get a lot of sympathy from Mike! :D
OkieSailor
Postby mikeschn » Sat Apr 16, 2005 3:16 am
Aluminum is very easy to cut.
Start with a piece of angle from Home Depot, and cut on your band saw, scroll saw, jig saw, or whatever... File off sharp edges and install! 8)
Images: 479
Postby TonyCooper » Sat Apr 16, 2005 9:40 pm
mikeschn wrote:Aluminum is very easy to cut.
Probably about 20 minutes work for each side.
My Tear Build Site
"No comment"
TonyCooper
Images: 35
galley hinge
Postby doug hodder » Sat Apr 16, 2005 11:43 pm
While I don't have my hinge installed, I plan on doing it this coming week. What I did was rout out the crossmember that the hinge mounts to. I routed it to the depth and width of the extrusion flange. That way, I can overlay the roof skin over the top of the hinge right up to the vertical hinge portion itself. I also ripped up a piece of wood to fill the gap in the extrusion. I can now overlay the roof so that it butts against the vertical portion of the hinge as I previously mentioned. No extra hinge showing. I won't have any silicone sealant except right at the point where the skin meets the vertical part. On the aft side of the hinge, Mine will tuck under the flange without adding any 1/4 inch piece. Just like a shingle on a roof. I get the same curve profile. By routing out that portion, everything lays down in place and doesn't rise up high on the roof. Just my ideas on it. I'll try to get a photo tomorrow and post it. Doug Hodder
Hurricane hinge
Postby J.T. » Mon Feb 18, 2008 10:41 pm
Ok, now as I understand it, you're spose to trim back the bottom ( hatch side) of the hinge about 1/8 or 1/4 of an inch on each side, right? But if you make your TD 4 feet wide? then how does the top piece hang out over the side? do you have to order a 5 foot section? instead of a four foot section? and does trimming the back part make water able to slide into the hatch? Isn't there a seam or small gap there where the hatch and the side meet? Originally I thought that building one would be fairly easy but I'm having trouble visualizing how the doors seal up, how the hatch seals on the side, etc. :( On the door handles? do the doors need to be a certain thickness or what?
:oops: Any and all suggestions and help would be apreciated. thanks guys , ahead of time.
Comparing what I have seen you guys build? I'll be doing good just to know what a board is.lol You fellas do outstanding work. Oh yeah, another thing, is there a site or anything that gives you help in building a woody?
J.T.
Re: Hurricane hinge
Postby grant whipp » Tue Feb 19, 2008 4:59 am
J.T. wrote:Ok, now as I understand it, you're spose to trim back the bottom ( hatch side) of the hinge about 1/8 or 1/4 of an inch on each side, right? But if you make your TD 4 feet wide? then how does the top piece hang out over the side? do you have to order a 5 foot section? instead of a four foot section? and does trimming the back part make water able to slide into the hatch?
Hi, J.T.!
I don't know how anyone else is selling theirs, but when you buy a Galley Lid Hinge from me (Li'l Bear Tag-Alongs - www.LilBear.teardrops.net/parts.html ), I send you 3/4" more than the overall width of your trailer's body - 48" wide body gets a 48-3/4" hinge - which nets a 3/8" overhang of the body side hinge piece on each side.
• The mounting flange of the body side piece (that part that screws onto the roof) should be trimmed flush with the sides of the body, leaving the "crown" and verticle locating flange overhanging the sides that 3/8" (depending on how you framed and cut/notched your Galley Walls, you may have to notch the locating flange to fit over the galley wall ...).
• Ideally, your Galley Lid should overhang your Galley Walls by 1/8" on each side, and the Galley Lid side of the hinge should be trimmed flush with each side (with its verticle flange trimmed flush with the bottom the Lid's overhang and even with the Lid's frame)
Before final assembly of the Galley Lid to the body, measure in about 5/8" to 3/4" from each end of the "crown" on the lid side hinge piece and carefully cut a 1/8" slot in that crown, enough to go through the "crown" but not all the way to the base, and mark the slot on the top flange with a pencil mark.
• At the time of final assembly (after everything is lined up and as evenly overhung as you can get), drive a #6x3/8" self-tapping sheet metal screw through the "crown" of the body side hinge piece into the slot of the lid side hinge piece - this will keep the lid from shifting from side to side.
This picture shows the old style Hurricane Hinge and the RV Roof Edge Moldings I sometimes use (the moldings, I mean ...), but I think you can get the idea of what I'm saying ...
Isn't there a seam or small gap there where the hatch and the side meet? ... I'm having trouble visualizing how the doors seal up, how the hatch seals on the side, etc.
Yes, there's a gap where the hatch meets the sides. The hatch sides (or ends) should have some kind of Roof Edge Molding with a lip that hangs down over the sides and (if you are lucky) hangs down past the galley walls a bit when closed. Most folks put the Hatch Seal (a closed-cell foam tape of some kind) on the overhanging portion of the hatch lid, against the lip of the Roof Edge Molding. Some folks put a narrower seal between the Galley Lid Hinge pieces, but if properly fit & trimmed, it's not really necessary.
If you use T-Molding to trim out the non-hinge sides of your side entry door(s), then Door Seal (another kind of closed-cell foam tape) is affixed to the inside of the T-Molding where it closes against the side wall(s).
That depends on what style of door handle & latch you choose. If you go with a standard L-Handle and slam-type latch, then thickness isn't really an issue, as the shafts on most L-Handles ara about 4" ...
Hope this helps and answers a few of your questions. Good Luck on your project! If I can be of further assistance, please give me a holler! As always, then ...
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
