Kayaker1971 wrote:Interesting options. May add a cheap little ceramic for quick heat up and a backup.
As far as condensation, my walls and ceiling are just plywood so there will be some, I planned to have a small vent fan running to reduce that. Besides the hanging blanket idea, do we ventilate with fan during cold weather to remove moisture and how to balance that with the heater?
I'm assuming most times this is at 365 campgrounds that have power?
The IDEAL solution so as not to need 120v would be propane, but have not found a safe small option for that. I saw a VW van with a propane heater underneath and thought that could be something that could go under mine but it looked too complex.
vincigj wrote:I to use small personal heater. Honeywell HCE100R Heat Bud Ceramic Heater, Red.
At 250watts too much. And if I turn it to low, 175watts, it worked fine in a 4x8 teardrop at 30f.
Tomterrific wrote:Electric blanket! One of the first camping trips in our trailer was cold. I bought an electric blanket (twin size) from Target. We put this on top of a sheet. The blanket is set on full before we go to bed so when we get in the camper it is toasty. The blanket is turned way down for sleeping, highest was 3 or 4 with mostly 2 or off. It is also nice just to lay on top with the blanket cooking on ten. :-)
T
booyah wrote:vincigj wrote:I to use small personal heater. Honeywell HCE100R Heat Bud Ceramic Heater, Red.
Actually really glad to hear this, I was eyeing this one, as a solution to my tear, with a small external thermostat.
I wanted something low enough wattage I can run it off my generator (hf 800w) without worry, but warm enough to make it worth it.
As it is the tear is very well insulated, R5 foam in all the walls, roof and floor, foam mattress, insulated doors, etc. We've camped out in high 30s to low 40s and maintained a decent internal temp (low 60s) with 2 people in side and one window and the roof vent just cracked, but I was worried about bringing it out any cooler.
