Recycled mini van.
Re: Recycled mini van.
Postby John61CT » Thu Apr 13, 2017 6:39 am
I actually love the idea aesthetically and from a green POV.
I just think, especially with the idea of leaving the longer length, so little of the total weight is behind the axle, if only one is left there. Lots of vehicles are pretty limited ball weight was the point of my "negativity".
With a strong enough tug I guess no worries, or for those not also wanting a lot of load capacity.
It oes sure make a sexy little tiny-house / steel tent.
John61CT
Postby GPW » Thu Apr 13, 2017 10:26 am
...and is pretty weatherproof too so can live outside ... :thumbsup:
The ones we participated in were not minivan conversions but full size vans (chopped ) ... one a 60 ’s Econoline with an extended areas behind the rear wheels which made the balance situation all the better ... gave lots more room inside too ...
A Quick Google of Vans into trailers images will give you many examples ... like this one ... ( see pic ) https://tse3.mm.bing.net/th?id=OIP.IU6u ... h&pid=15.1
Postby GPW » Sat Apr 22, 2017 5:45 pm
Saw this ... Too cute ...
Postby KennethW » Sat Apr 22, 2017 9:04 pm
I am just starting a redneck flat bed trailer to haul 4x8 sheeting, using a minivan floorpan and axle.
Cutting the roof off above the sidewalls and remove side doors.
Cutting the front of the floor pan, Just in front of the rear seat bolts(a strong point with cross beam).
Angling the sides to get behind the door pillars.
Then planning to bolt square tubing for a V style tongue.
Today I cleaned out the inside plastic,carpet,seat belts remove the quarter glass, and cut the back four pillars.
Will get back to you guys. on the finished trailer.
KennethW
Images: 82
Postby GPW » Sun Apr 23, 2017 4:45 am
Ken , please send pictiures ... :pictures:
Postby John61CT » Sun Apr 23, 2017 8:57 am
Interesting, hacked unibody trailer
John61CT
Postby GPW » Sun Apr 23, 2017 10:02 am
J61... Kinda’ makes you think about a new idea for a Camper floor ... maybe an old idea ??? :NC
Ken, what’s your take on that ??? Minivan teardrop floor ... “ Uni-trailer “ :thinking:
Postby KennethW » Sun Apr 23, 2017 12:05 pm
The main problem of a minivan floorpan in the axle placement. It make for a heavy tongue.
But if mounted the galley floor on a hitch storage rack it would solve the weight problem.
I will be better informed after I cut the van up.
KennethW
Images: 82
