Is your AC running hot?
Postby john » Fri Jun 16, 2006 1:51 pm
Tear Fan said:
If I put a vent in the floor of the galley for heat exhaust, won't that allow water up from the road when in transit? Anyone? Anyone? sweaty
In my experience holes in the bottom of the trailer have been problem free. I did all my venting (A/C and otherwise) through the bottom of my trailer so as to hide the a/c from view. I think the A/C box is ugly therfore I chose to hide it. I felt that venting through the galley was a poor choice because I would have to keep the galley door open during rain (a humid time when the A/C is needed) and night when I wanted both water and critters out. In the end I decided that water was more likely to get in through an open hatch than a hole in the bottom of the trailer. I also rulled out vents in the side of the trailer for asthetic reasons.
I did consider the splash and spray issue and decided that if it was necessary I would construct a skirt around the holes. As yet they have not yet been a problem.
A few pics:
http://pg.photos.yahoo.com/ph/johngwalk ... pg&.src=ph
There is also a tear build link at the bottom of the page.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby Tear Fan » Fri Jun 16, 2006 2:09 pm
John - I like it! I like it! Do you have any kind of vent screen or covering below the A/C in its little box? Is it sealed up tight? What is the vent below the A/C in the cabin. Is that a heater to the right of the A/C in the photo? And, finally, what in the heck does "Penomeli ikibobo" mean?
:o
Life is so short, we should all move more slowly. - Thich Nhat Hanh
Photos - http://flickr.com/photos/47726343@N00/
Tear Fan
Images: 70
Postby asianflava » Fri Jun 16, 2006 2:47 pm
Woody wrote:If you have the right venting for incoming cooling air to the A/C unit you can run it with the galley hatch closed. I have no problems for almost three years open or closed.
The way I have mine setup, it draws air in from the galley and exhausts it out thru thr top. I ran it 24hours a day for 4 days, with the hatch closed most of the time, without any problems. The hatch was closed but it wasn't latched. I'm pretty shure my hatch isn't 100% sealed.
asianflava
Postby john » Fri Jun 16, 2006 3:20 pm
I had planed on (and bought) screens to cover each hole (the kind used on the eaves of homes with the screens attached to metal louvers). I thought that if they were turned the right way they would keep water splash as well as bugs out. So far neither have been a problem. My time insted has been used on unfinished trim bits.
I built the AC platform with that PL glue stuff from Lowes so all gaps are sealed. The front of the AC is trimed in with Luan and held in place with screws for possible repair reasons. The back of the AC is covered with the same kind of luan as the front and is held in place with only the row of screws at the top. the bottom is fitted behind the flooring.
The vent at the bottom in the cabin: The area below that vent is a low pressure area where air is drawn into the condenser by the AC. I tapped into that low pressure area to draw air out of the cabin and fresh air in while the AC was on to keep 02 levels up. Also, with the AC portion of the AC turned off and only the fan running I would, in effect, a roof vent with out an actual roof vent.
Yes, to the right of the AC is an electric heater.
Penomeli ikibobo: Back in the late 80s Isuzu ran a few ads that starred Joe Isuzu. He would blatently lie about the cars he was selling. Toung and cheek stuff like having 1000hp. He would sign off saying penomeli ikibobo. I liked the ads.
Penomeli ikibobo
john
john
Images: 261
Postby Gadget Man » Fri Jun 16, 2006 4:34 pm
Wow, a lot of great ideas here.
The bigest one being that the A/C unit has to be able to dispell the hot air, they have to breath. Period.
I'm agreeing with Dooner, you need a clear discharge shot out the back to make sure they are able to breath.
If you look at my picture the the left of this post, see right by my left knee, thats a little door that I open only when I'm running the A/C unit.
This is a 18x21 boxed in discharge chute, it's the same size as the back of the A/C unit or even a bit bigger. If I ever have any trouble I can pull it straight out the back for service or replacement, (Don't forget that).
I also placed the entire A/C unit in a 2" deep tin tray with a slight slope to the corner to collect the condensate, it drains to a fitting with a pipe going
through the floor.
I do have to leave this door open when running the A/C but who cares, it's mostly at night anyway.
Good Luck
Gadget Man
My kids may be smarter than me,
But I know more.
Gadget Man
Images: 23
Postby Dooner » Fri Jun 16, 2006 5:16 pm
Hey Gadget Man,
Thanks for agreeing wit me. In my opinion, it's great to get it into a hiding spot out of the way and look good, but the unit was designed as it is, so to get the full function of it, it is best to install it so it can function.
I was thinking of a same design as yours with a full vent door. Who cares if the vent door is open, as long as I'm cool. I'm not sure if I will go to the front or rear of the TD. Since I haven't even started yet, I got some time to figure that out.
I checked your album and did not find any pics of the a/c install. It would be great if you could add some pics of it. Front and back. Back with door open. Close details.
Great job.
And all the other guys,
Great job on yours too. If you can get it to work in the spot where you want it, thats great. That is what it's all about, making yourself happy (and if your like me, the wife has to be happy first).
Dooner.
TED NUGENT FOR PRESIDENT!
Dooner
Images: 69
Postby Steve_Cox » Fri Jun 16, 2006 5:28 pm
Here's another way to exhaust the hot air from the A/C without having any openings in the sides or top of your TD. That's a 6" exhaust fan and blast gate at the bottom to keep the critters out when the A/C is not in use.
Steve_Cox
Images: 196
Postby Dooner » Fri Jun 16, 2006 5:34 pm
[quote="Steve_Cox"]Here's another way to exhaust the hot air from the A/C without having any openings in the sides or top of your TD. That's a 6" exhaust fan and blast gate at the bottom to keep the critters out when the A/C is not in use.
Thats cool. Speaking of cool, where do you get the intake air from?
Dooner.
Dooner
Images: 69
Postby Gadget Man » Fri Jun 16, 2006 6:27 pm
Dooner
I know, I know...
Mad Jack has been after me too, to get some more "pics" posted.
I only have a couple hundred build photos, I have them all in an album and boy am I glad, I've had to refer back to them many times while adding the finishing touches to the rig. I needed to remember where my wires were run through the walls before I added some inside coat hooks.
Stuff like that.
I'll try to get my 14 year old son to sit still long enough to help me (Again) with posting some more photos.
Gadget Man
But I know more.
Gadget Man
Images: 23
Postby Steve_Cox » Fri Jun 16, 2006 7:03 pm
Dooner wrote:
Steve_Cox wrote:Here's another way to exhaust the hot air from the A/C without having any openings in the sides or top of your TD. That's a 6" exhaust fan and blast gate at the bottom to keep the critters out when the A/C is not in use.
Intake air comes in at the top of the bulkhead just behind the galley hatch hinge, or if the galley hatch is closed I have an vent inside the TD that I open.
Steve_Cox
Images: 196
