Stick out your tongue and say "ahhhh" . 2"x2" square tube is nifty & all, but don't get all wimpy with the wall thickness! Mine was 1/8" and really needed to be more. And now I'm thinking that the outer tube should extend out longer, as Guy suggested to me. I'm sort of hashing it over now. If you *never* do anything more than putt along the street with light loads, properly balanced, then maybe the 1/8" wall will do. But it only takes once to smash it up quickly. Baja washboard road will do it!!! Just ask Larry Sorensen!
http://www.outbackteardrop.com/
I still like the single tongue because it's not always in the way when I need to get into the back of the Jeep, but I'm going thicker next time. 1/8" is apparently ok for the frame, but the spot where all the forces come to bear needs to be a lot stronger! Oh, and if I did have a welded "A" frame tongue, it would have been much less likely that I could have made such a trail repair and been moving again so quickly. In my case I was able to substitute part of a Hi-lift jack and was on my way in 2 hours.
More photos on this here:
http://www.roughwheelers.com/montego/TD/BajaAdventure2004/index_4.html#PICT1849.html
