All Hell Broke Loose
Postby Geron » Sat Feb 12, 2005 6:47 am
arnereil wrote:Just a note on holes. Think of it like an I-beam. The major strength comes from the top and bottom.
My take is, if you have to drill holes, put them through the sides.
Based on this info I'm having second thoughts about "bolting" the battery mount angle iron to the tongue as outlined in the Kuffle Creek Chubby. That would require drilling 2 holes in each side of the the tongue on the bottom of the channel. Think I'll weld them on.
Geron
Geron
Images: 173
Postby Arne » Sat Feb 12, 2005 9:03 am
Angle iron brackets could be side bolted to the tongue and the battery box bolted to the angle iron.....
Or.. you could weld them.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Dave Nathanson » Sat Feb 12, 2005 12:12 pm
I never thought that my old 2x2 (1/8" wall) sq tube tongue was weak. It felt way solid. But there is a big difference between the amount of force I can put on that pipe myself, versus how much force a Baja dirt road can whip up. I'm sure the trailer was bouncing in the opposite direction that the Jeep was bouncing much of the time. Anyway, the fewer holes drilled in such an important piece the better, and the tongue is one piece that you WANT to overbuild. Hey, a little more tongue weight is GOOD, right?
Of note; the 2.5x2.5 (1/4" wall) did not break, or bend. But it did open slightly. So I've supported that with a 3x3 (1/4") sleeve.
Any now that I've proven that 2x2 (1/8" wall) is not a suitable tongue material, I'm going to see if I can prove if 2x2 (1/4" wall) square tube is acceptable. (!)
Dave Nathanson
Images: 18
Postby dmb90260 » Sun Feb 13, 2005 10:44 am
But will it be able to carry your portable welding kit?
Enjoyed the pictures of your adventure :o and how you solved things. :thumbsup:
Dennis
Join the Kenskill Karavan at:
http://autos.groups.yahoo.com/group/kenskill_karavan/
Real Men cook with Black Iron
The Buzz In the Dale: The Buzz In The Dale
dmb90260
Titanium Donating Member
Images: 134
