mikeschn wrote:The floor should be sitting on your chassis, which should already be level.Mike...
kartvines wrote:Yes I understand that my floor will already be bolted onto my trailer, my concern are then what. I want to be able to attach my sides without worrying about it dropping while I drill and then set my screws. the glue should be no problem, being I can apply it first, but then the sides will be lube up ready to slide while I start the attaching. On my Scad-A-Bout, the sides do not rest against the floor, they have to be held in mid air, lining up to where they are screwed onto the floor.
