I'm going to put these "By Guess & By Golly" drawings away for a minute and do some math... (It's kinda hard to draw it right without having the part or a good picture to work with)
Overall body width:
63 1/2". (Will probably increase by 1/8" with epoxy glass and uv inhibitor)
1" tire clearence between body... add 2" =
65 1/2".
Tire Salesman tells me that the tire will hang over the edge of the wheel by 1/2"... add 1" =
66 1/2".
The backspace of the 14" x 6" wheel is 3 3/4"... add 7 1/2" =
74".
OK... 74" should be my hub face to hub face dimension.
Now I subtract that minimum hub face to mounting bracket dimension of 6.185" twice... 74" - 12.370" =
61.630". (Just a tad over 61 5/8")
OK...That tells me that the square axle tube is going to be 61 5/8" long.
It also tells me that the frame is a bit too wide also...
Frame Rail width: 62".
Interior dimension of subwall to subwall skirt: 62 1/2".
Clearence between frame rail and subwall skirt 1/4".
Easy solution... Go with more tire to cabin wall clearence and increase Axle tube length to at least 62" (Maybe go 62 1/4" just for extra swing arm clearence)
Other option... Narrow up frame width and use more clearence around skirt area. (I dont like this option because I'm loosing shear support for wall framing)
Creative solution... Narrow frame width just at axle/ swing arm location.
(I would probably notch-n-box, then utilize longer gusseted axle mount on back side of boxed in notch for added strength)
Gonna think this one over... That notch-n-box does sound like a sanitary solution.
My wheels and tires should be here by this Saturday, so I'll be able to order the axle first thing next week.
BTW- I got a price to get the baby moons copper plated... $150.00
Thanks for your continued help Cary...
