by Nitetimes » Sat Mar 26, 2005 2:23 pm
Here's how I'd go about it. First donate those bearing buddies to the local landfill. Next, if you don't already have the hubs off you need to remove them, remove your outer bearing, then you can use a puller or or get behind the hub with a large hammer and pound it off of the seal. To get the bearing off what I usually use is a fairly thin chisel, just tap it between the race and the spindle shoulder, keep moving it around til it pops loose. As long as the bearing has spun it will usually loosen up with minimal persuasion. Don't worry about the shoulder, as long as you don't get crazy on it it won't be hurt, it's just a stop for the bearing besides if you bung it up a bit just grind or file it back to smooth. Be careful not to tear up the area the seal rides on tho.
You can try a gear puller but the bearing race is usually not much bigger than the shoulder on the spindle so it usually won't have anything to grab ahold of.
As for greasing, just pack your bearings with a good high speed bearing grease and put a thin layer on the races in the hub, replace the seals, put it all back together, put the spindle nut on and tighten it snug while spinning the hub then back it off a little, do this several times, the last time you snug it back it off to the first available cotter pin hole, put your cotter pin in, bend it over taking care to make certain it won't rub the grease cap (I've seen them cut thru), put the grease cap on and your done. You shouldn't have to touch them for at least a couple of years.
Replacement bearings should be able to be found anywhere that sells bearings, it's best to take them with you so they can get the numbers off of the side of them. You will need to take one of each bearing and race (from the hub) also take the seals with you. Try to make sure you take parts with the numbers on them. They might be hard to see unless you clean all the parts really well. And some aren't numbered at all so they'll need to measure them.
Rich
- Thomas Jefferson -
