Laun & Plywood sandwich?
Postby Syekick » Mon Apr 04, 2005 6:02 am
Based on an earlier thread I've a question.
http://tnttt.com/viewto ... highlight=
For the sidewalls, it appears that Mike is using the 1/4" laun without mounting it to another sheet of plywood. (Before it goes against the frame.) Is that correct Mike?
That may be fine for the sides but I would think that the top would require at least two sheets of 1/4" Laun, one on top oe the other to give it enought strength from road damage.
<b>Fudd's First Law of Opposition: </b>
If you push something hard enough, it will fall over.
Syekick
Re: Laun & Plywood sandwich?
Postby mikeschn » Mon Apr 04, 2005 6:23 am
Syekick wrote:Based on an earlier thread I've a question.
The weekender is a stick built, luan covered, extruded polystyrene insulated teardrop. When complete it'll have the strength and rigidity of a SIP (structural insulated panel).
1/4" luan, re-inforced with EPS should be plenty strong. If you are not convinced, then add a layer of fiberglass to the outside before painting! :D
Images: 479
