Guy wrote:Dear Kai,
I am concerned about the propane and the battery sitting that clost together. A spark, regarless of venting can be all it takes. If you put the battery in a separate box, separately vented you overcome the danger.
Dean in Eureka, CA wrote:Kai,
Did you end up going with a Flexiride?... Because the swing arms are positionable. You can set whatever angle you need. Just have a good pair of glasses to count how many splines you move it, so the other side gets moved the same amount.
scruffy wrote:kAI
DO YOU STILL SELL THE STOVE AND OVEN? IF SO HOW MUCH? BEAUTIFUL WORK B.T.W.
