I've been quiet up till this point. So I guess, now it's my turn...
Glue... yea, I think there's a glue for every reason and every season.
I use polyurethane glue on the subfloor and other places that see extreme moisture. These glue joints are fully backed up by mechanical fasteners.
I used Titebond II on most of my woodworking, but if I were to do it again I would probably use Titebond III. These joints are typically backed up by biscuits or screws.
Yea, can you tell, I like redundant fastening? Anyways, you can probably use what ever glue you are comfortable with, as long as there is some water resistance. And if you are not sure about a joint, put a screw in it!
Above all have fun, and don't sniff it too long!
