Folding doors for bathroom?
Postby wolgie » Sat Jun 02, 2012 11:51 am
I know I saw a thread about this but I can't find it. I'm trying to figure out a way to make folding doors/door for the bathroom in my TTT vardo to save space when it's not in use. any ideas or links would be much appreciated. I am using the tap talk app on my phone and I don't think the search functionality is as good as online.
Thanks
Wolgie
Wolgie
See the creation of the WolgieWagon build Journal here viewtopic.php?f=50&t=50466
wolgie
Re: Folding doors for bathroom?
Postby angib » Sat Jun 02, 2012 3:18 pm
Was it this one (or which I am inordinately proud):
angib
5000 Club
5000 Club
Images: 228
Postby wolgie » Sat Jun 02, 2012 9:28 pm
That seems like the setup I have planned. But how does it work I can't tell, I'm on my phone if it's animated then that's why I can't see it. Im camping right now:)
Wolgie
wolgie
Postby petertl » Sun Jun 03, 2012 5:39 am
I used the cheap vinyl accordion style door.
petertl
Images: 15
Postby wolgie » Sat Jun 09, 2012 10:09 pm
Yes angib that was it. Thanks, I am trying to decide between something like that and just a couple of accordian doors like the previous post. I just don't know yet. Thanks guys for the input.
Wolgie
wolgie
Postby mezmo » Sun Jun 10, 2012 8:50 pm
This is sort of a verbal description of what Andrew's animation
shows:
Just use a couple of plywood panels or thinner dimension frames
with thin ply panels/veneers and a couple of long piano hinges,
or some other more robust hinge. I advocate using piano hinges
to help impart extra strength and rigidity as the hinges for this
style of folding door take a lot of stress in their dual function of
support and movement. Piano hinges are simple and straight-
forward. Their benefits outweigh any additional cost I think.
On the "MAIN" bath door - the one you see as the 'bath entrance door'
from the inside of the camper -, use the first piano hinge to
attach it so that it opens into the inside of the camper in the
direction you want it to. On the INSIDE of that MAIN bath door
[the "outside" door of the two when looking from the PP/toilet
position], on the opposite side that the MAIN bath door's piano hinge
is on, install the second panel/door with the other piano hinge.
[You could also install a third panel if you want "total" enclosure,
but would be extra material and additional weight for the animation's
design - it just depends on your design and needs.] Just remember
to install the MAIN bath door piano hinge in a manor so that that
door can swing out to flat against the plane of the interior cabinets
face or seat(s) inline with the MAIN door when it is normally closed -
or in other words, 180degrees of movement for the MAIN door outwards.
[This allows you be able to 'get around' the door from the interior and
position yourself in front of the PP/Toilet so that you can pull the
enclosure into position with you inside of it.] The inner door needs
it's hinge mounted so that it can swing out to 90 degrees from the
MAIN bath door, so that when you pull back the MAIN bath door with
the Inner door at the 90 degree open position, that it's unhinged
end will rest against the end wall to complete the enclosure as per
the animation.
I would avoid the vinyl accordion doors myself, based on personal
experience. They're not long lived enough for their cost and they can
stink - especially the cheaper ones. Just my opinion on them.
Norm/mezmo
mezmo
Images: 167
Postby wolgie » Tue Jun 12, 2012 8:11 pm
Mezmo thanks for the thorough description. The piano hinges do sound like a good idea. Thanks for elaborating.
Wolgie
wolgie
Postby wolgie » Wed Jun 13, 2012 9:17 am
Matthew are you by chance a folding door salesman? Like John candy in planes, trains, and automobiles. But instead of shower curtain rings its folding doors? :)
Wolgie
wolgie
Postby jstrubberg » Fri Jun 29, 2012 9:15 am
Folks, we have a bot. Mike, can you see the IP on this thing?
:x
jstrubberg
Postby doris s. » Fri Jun 29, 2012 9:24 am
You could also just build an "arm" that folds out the same way the doors do but use shower curtains instead of a full door to save weight.
Doris
doris s.
Images: 23
Postby wolgie » Sun Jul 15, 2012 4:30 pm
I actually had the same thought at fort Davis this weekend when I was in a restroom at a local restaurant and they had a curtain for a door on the stall. Great idea, but for those of us that like that extra privacy to do our business I have come up with another idea. Check out my journal, I will post a diagram later to explain it better. Thanks for the suggestion!
Wolgie
wolgie
Postby wolgie » Mon Jul 30, 2012 11:15 am
I figured out how to do it on my wagon.
Wolgie
wolgie
Users browsing this forum: Google [Bot], rebapuck and 8 guests
