Rerun
Rerun
Postby Sidekick » Wed May 28, 2014 8:24 am
Having built several boats and other projects I know how hard it is to weatherproof seams. Tghat is why I am starting out with a weather prooftop taken off of an old coversion van. It has some nice curves and should look spiffy when the package all comes together.
Total spent to date
Fiberglass topper- 50.00 local pick and pay
axle- 0 ( donated by one of my friends)
frame metal -78.00
wood for floor 34.00- Home Depot
wood for framing- free ( taken from crated a/c units at past job
Lights- 32.00
wiring- free ( left over from Dune Buggy fab
switches- 6.00 off ebay
Inverter- Donated by my father
The adventure begins
I am calling the trailer RERUN because it is mostly made up of salvaged pieces and parts giving them a new purpose..
Once I figure out how to upload pictures I will post them
" Chances are- if you don't know where you are going, you will never get there"
Sidekick
Images: 82
Re: Rerun
Postby 48Rob » Thu May 29, 2014 6:36 pm
SK,
I look forward to pictures, sounds cool! :thumbsup:
Rob
48Rob
Re: Rerun
Postby dodgedartgt » Thu May 29, 2014 7:37 pm
Subscribed!!!
Often, walking through the yards, I've looked at not only the conversion vans "below" the fiberglass toppers, but also at the toppers themselves as a solid starting point. I'm anxious to see what you arrive at.
And above all else, I'd say you are working on MY budget! LOL
Mike in FL
dodgedartgt
Re: Rerun
Postby ctstaas » Fri May 30, 2014 1:01 pm
Hi SK, I like your minimalism. The plans I used said my build should cost around $700. $2000 later and I have a fine TD. Still room for improvements too-Yippie!
Enjoy Yours, Chris
ctstaas
Re: Rerun
Postby Wolffarmer » Sat May 31, 2014 10:11 am
Good idea on that van top. I always keep my eye open for a small boat.
Randy
Wolffarmer
Images: 309
Re: Rerun
Postby Frankelson » Tue Nov 04, 2014 11:21 am
We're using a pickup truck canopy, for the same reason as you - at least the top bit will be leakproof. :-)
Any pics of your build yet ?
Best Cheers
Frank
I !__[_]|\___
I ____|"_|"__|/
"(o)======(o)" Range Rover 4.6 HSE
Frankelson
Re: Rerun
Postby Sidekick » Wed Aug 10, 2016 5:55 pm
122970
Sidekick
Images: 82
Re: Rerun
Postby 48Rob » Wed Aug 10, 2016 6:54 pm
Looks pretty cool from here! :thumbsup:
More pictures please...
Rob
48Rob
Re: Rerun
Postby aggie79 » Thu Aug 11, 2016 9:30 am
48Rob wrote:Looks pretty cool from here! :thumbsup:
Rob
I'm with Rob. That is a very nice build. In looking through your gallery pics, the interior looks like you covered the walls and ceiling with carpet (or hull liner or speaker enclosure fabric.) How'd you frame the walls?
Take care, Tom
Re: Rerun
Postby Sidekick » Thu Aug 11, 2016 5:46 pm
The trailer was framed with 2x2, lined with 3/4 foam then inside skin was 18 in hard board with decking carpet glued with scotch 77 high bond. Makes it nice and quiet inside
Sidekick
Images: 82
Re: Rerun
Postby Sidekick » Thu Aug 11, 2016 6:14 pm
Frankelson wrote:We're using a pickup truck canopy, for the same reason as you - at least the top bit will be leakproof. :-)
I tried the pickup topper thing and they were way to heavy and most times had too much glass in them. I had in my pile 6 toppers that I got off craigslist for free. I relisted the glass and hinges on Craigslist and was able to get gear for the trailer.
Sidekick
Images: 82
Re: Rerun
Postby Sidekick » Thu Jul 13, 2017 6:06 pm
There are plenty of pics that I have posted of the build. The trailer has survived 2 years of use with only a rear hatch problem that was easily solved. I am on to my second attempt
Sidekick
Images: 82
