I built a shunt that measures the drop in voltage across the resistors. When compared to the value of the battery the pannel is now able to calculate the amps drawn. This will be helpful in monitoring the amp- hours remaining in the battery.
The way a 12 v system is used ( how deeply you discharge the battery) will determine how long the battery lasts. I am reading that it is generally best not to discharge below 50% of the battery potential capacity or 12.06 v. The values posted above seem to be correct...
I have seen the same values on several other sites.
Here is a great source of info
http://bart.ccis.com/home/mnemeth/12volt/12volt.htm
BTW my panel meter and shunt are the very first electronic projects I have ever made. It works and it wasn't that hard.
Happy Camping
DEE
