Vedette wrote:I think the Little Guys use an air conditioner that sits next to the trailer and plugs into the permanently installed inlet and outlet.
But, it is stored and transported separate from the TD.
Brian
ibbowhunting wrote:the pictures of new ones show a/c unit in the bulkhead of the galley I believe ? and I also seen in a walk around video an a/c vent on both sides
JaggedEdges wrote:I have a feeling a 5000 BTU won't help much with humidity inside a teardrop. It won't run long enough (Presuming you set the thermostat to 20c) By my spitball, you could have a black painted TD in death valley and a 5000BTU would be powerful enough to use the thing as an ice cream freezer, with any small amount of insulation.
These will do about a 12x12 room, 8 foot ceiling in a house, that's about 1150 cubic feet... how many cubes in an average drop, about 120?
But I know right, you can get them for $80 on sale.
Thinking of this conundrum, I did some digging, and came up with this little bugger..
https://www.plasmacoolstore.com/Persona ... ion=US#buy
However, it does need some re-engineering. Note that it's a bit of a dumb product, in that it blows the hot air out the back, into the same room, so it's kind of a spot cooler. Also contains a drip bucket which makes it bigger than it needs to be. However, I see nice possibilities there, stick in kitchen unit with it's cold side in. It sucks about 250W, so it might run off a decent sized leisure battery and inverter for one night of cool sleeping, 50% duty cycle, which I think would be a darn hot night, typically it would probably run 25-30. If you've got 300W of solar, you could do that night on night. Or use it for an hour a night to get comfortable to sleep for a week.
Anyway, not saying you're wrong for wanting to use best locally available for cheap, just saying "Here's an idea" for sub arm+leg cost unit that's better suited maybe.
