Low noise Generator and A/C U units
Postby NugHunter » Fri Dec 04, 2015 11:55 pm
Hi all new here so thought i would jump in head first with 2 of the main things i am interested in at the moment.
A small low noise generator...prefer 1500w or less...quieter the better ...
a very Small a/c window unit...of coarse low wattage and if it has a heater too that would be great
my camper is appox 4x5x8
any comments ,tips or observations are appreciated...
EL Eye Vee Eye En ...Livin ;)
NugHunter
Re: Low noise Generator and A/C U units
Postby noseoil » Sat Dec 05, 2015 9:09 am
The best generator for what you need is the little Honda at 53-59db at low speed. Yamaha also makes one. It's plenty quiet & runs efficiently. They both run at 80-85db with a load, so take your pick. Ryobi makes one as well, but I don't know about it. It's less expensive than the Honda or Yamaha at $600 at Home Delay.
A small window AC unit is about where you will end up, but how it gets installed is always the issue. It can run on low, so just figure it's a trade off between noise & cool....
https://www.youtube.com/watch?v=K3dKnTl5RYo
137905
noseoil
Images: 669
Postby Tomterrific » Sat Dec 05, 2015 9:21 am
I went to an autox where the small two-cycle generator powering the equipment was loud. At least on the side away from the timing stand. Someone had taped together a foam box with an open side that faced away from people. I was impressed how much noise reduction a simple box gave that generator.
Tomterrific
Postby Redneck Teepee » Sat Dec 05, 2015 10:47 am
You will pay for a quite generator, it's not primarily about a muffler, it's knocking down the mechanical noise from within the unit as well.
Redneck Teepee
Images: 21
Postby MtnDon » Sat Dec 05, 2015 11:43 am
Honda or Yamaha inverter generator. These will run forever given the recommended care.
Small window shaker A/C. Most are too big but they are about the best you can do.
MtnDon
Images: 24
Postby drhill » Sat Dec 05, 2015 3:10 pm
I don't use a generator when camping and am usually not too pleased when my neighbour is. But I was surprised last summer by a guy with a Honda EU3000is. It was really quiet, especially as he had it lightly loaded. He had a really big 5th wheel trailer so weight was no concern.
If I was to buy a generator - the EU2000i would be my pick. It is only 30% more $ for double the engine size and peak power and could normally be run at a lower percentage of loading than the EU1000i with the same load. So the EU2000i would run quieter. A EU1000i would likely have a tough time starting even a 5000 btu a/c unit. I am not familiar with the Yamahas & they are likely worth a good look too.
MODEL EU3000is EU2000i EU1000i
CDN Price $2,349 $1,299 $999
MAXIMUM AC OUTPUT (WATTS) 3000 2000 1000
MAX CONTINUOUS OUTPUT (WATTS) 2800 1600 900
DISPLACEMENT 196 cc 98.5 CC 50 CC
NOISE LEVEL dB(A) 58** /48*** 59** /53*** 57** / 52***
(100% load/25%load)
DRY WEIGHT 59 kg (130 LB.) 20.7 KG (45.6 LB) 13.0 KG (28.7 LB)
drhill
Images: 37
Postby lrrowe » Sat Dec 05, 2015 3:58 pm
http://www.electricgeneratordepot.com/ has the EU20001 on sale for $859 with free shipping. Not sure how long the price will last. I would order one now except I have a few other high dollar priority items on my list.
Bob
lrrowe
Images: 439
Postby rowerwet » Sun Dec 06, 2015 3:37 pm
Harbor freight now sells a quiet generator, read up on it first, some stuff is good and some isn't there.
https://youtu.be/wFF073UpZuM
http://m.harborfreight.com/2500-peak220 ... 20provided
rowerwet
Images: 521
Postby Redneck Teepee » Sun Dec 06, 2015 4:48 pm
rowerwet wrote:Harbor freight now sells a quiet generator, read up on it first, some stuff is good and some isn't there.
One of the problems with these offbeat brands is service or warranty work (parts).... I'm not knocking them, I'm just saying should the need arise, I think you are in for a long turn around repair time vs a common name brand.
Redneck Teepee
Images: 21
Postby rowerwet » Sun Dec 06, 2015 5:24 pm
Depends where you live. I have a HF store 15 min away. I can return the unit for a new one if they can't get me replacement parts.
I bought the HF 20 ton wood splitter and made sure the warranty was worth it. I've split 7 cords now and the splitter is impressive.
The predator engines are exact copies of Honda, if you need to replace a part just look it up and order at your nearest Honda dealer.
rowerwet
Images: 521
Postby lrrowe » Sun Dec 06, 2015 5:49 pm
Or how about this one.
http://www.generac.com/all-products/gen ... ies/iq2000
It also looks interesting.
Bob
lrrowe
Images: 439
Postby bdosborn » Sun Dec 06, 2015 6:18 pm
drhill wrote:If I was to buy a generator - the EU2000i would be my pick.
I wouldn't buy anything smaller than a 2kw. My 1Kw Yamaha generator will not run an A/C unit.
Images: 777
Postby booyah » Mon Dec 07, 2015 10:01 am
FWIW I did some research on the various inverter generators a few years back when I was looking at doing an off grid cabin
The ranks seemed to be
1. Honda
2. Yamaha
3. Hyuandai / Ryobi
4. Champion
5. Generac
6. Everything else
I did a ton of research, was all set to pull the trigger on either the Hyuandai or the Ryobi as the price/review point was good for me.
Then I got a 2 cycle harbor freight one from my dad as he got a good deal on em. That and a 50ft cord that puts it on the other side of the TV, and its good for me.
As far as noise bothering others, I only run a generator if I am off in the boonies somewhere, and only to either recharge the battery, or run a load that is too large for battery (heat or AC) and turn it off after I'm done with that load.
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby lrrowe » Mon Dec 07, 2015 10:09 am
booyah wrote:FWIW I did some research on the various inverter generators a few years back when I was looking at doing an off grid cabin
1. Honda
2. Yamaha
3. Hyuandai / Ryobi
4. Champion
5. Generac
6. Everything else
Like I do with my not so portable Champion 2000 which is not a light weight version. But I would like more quiet and portability.
And a few years ago the Generac was a IX2000 which did not have good reviews from what I can see. In July of this year, they introduced a new model, IQ2000, which looks promising. It is so new that it is not in all the retail locations yet. MSRP is $799.
Bob
lrrowe
Images: 439
Postby booyah » Mon Dec 07, 2015 2:05 pm
That new IQ2000 does look pretty nice, I like the fuel gauge and load meter.
Definitly looks nicer than the old one.
Dont know if its $200 nicer than the Ryobi the Hyundai though...
http://www.homedepot.com/p/Ryobi-2-200- ... /203617901
http://www.amazon.com/Hyundai-HY2000si- ... B004919NEK
booyah
