by daveesl77 » Thu Oct 06, 2016 8:33 am
Well, with Conch Fritter, which is sized as 10'L x 5.5'W x 5.5'H, we built it to have plenty of storage, while at the same time providing a lot of comfort. To do this, we had to go unconventional in a primary area- the galley. In the vast majority of trailers the galley area is a permanent fixture, in the back, accessed by way of a hatch. This has a lot of advantages, such as a preset cover over the galley. The disadvantage is the galley takes up interior room. With ours, due to the height, our queen bed sits on a raised platform. The galley rides under the bed, slides out the rear, does kind of a "transformer" thing, as it rotates into an "L" shape, then the two cabinet section ends flip over to create the sink and a stove table. To the left and right sides of the bed are compartments that can be accessed from the top, 3 compartments on each side. Where the curved front is, we built in a cabinet and shelving area. It also holds a small dorm type fridge and the electrical control panels and components. This then gave us an area of about 2' x 5' open floor space for our feet and mainly our old beagle Max.
The negative to our design is the need to put up a shelter/canopy/cover over the galley. It takes about 5 minutes to fully set up or reset the entire galley system, this includes water lines, water heater and propane. With a normal design this can take seconds, as you only need to close the hatch. However, with our slide-out galley, we have almost 11 linear feet of "counter-top" and 13 cubic feet of additional cabinet storage. In addition, we did not have to build a hatch, but instead have a recessed door access, so there are no top opening areas that can allow in water. We've had our system set up in some pretty strong thunderstorms with no problems.
There are pros and cons to ever build and no build is perfect. Don't look for perfection, look for what best suits your needs.
dave
