if you are still concern'd give this a try
jack both tires off the ground and secure on jack stands under the axle where the suspension is bearing the load as it would running down the road
take a piece of tape and place it across the tread on each tyre
put a mark on the tape on each tyre
w/ a helper get on the ground and measure the distance between the marks
do this 3 times
horizontally at the mid point front & rear as well as at the very bottom
if your tyres are completely under the frame during normal travel measure at the top vertically centered
if you get the same measurement at all 4 points you have zero camber & zero caster
anything other than the same measurement will tell you where your issue(s) are/may be
the issue you described could be something as simple as a loose bearing(the axle nut has excessive play)
if there is just a slight bit of bearing wear it can relax the adjustment/tension on the axle nut and allow the wheel/tyre to ride just a bit off true causing the result you experienced
at each fuel stop i use the back of my hand to check the temperature of the tyres, my finger tips to check the temperature of the hubs and grab the top of the tyre and try to wiggle it in & out
if the back of a mother's hand is good enuff to tell the temperature of the milk she is feeding her infant it is good enuff for tyres
your finger tips should be able to detect any differential in hub temps
and if the bearings are the least bit loose your hands will feel and your ears will hear a bit of a clunk
of course it is never wrong to jack each tyre off the ground and spin it at the beginning of the season or b4 a trip, listening for a gravely growl emitted by wonky/dry bearings. no growl no foul
you said NEW TYRES installed & BEARINGS REPACKED so...
GOOD LUCK
sw
