Trailer security
Trailer security
Postby bluski » Mon Nov 14, 2016 7:10 am
Newbie here, first post. Just picked up a homemade 4x8 and looking forward to all the challenges. While I'm "wintering" away from home, my trailer will be stored in the parking lot of the complex where I'm staying. Besides the "ball socket lock", what other reasonable steps can be taken to prevent the trailer from disappearing. I sure don't want to haul jack-stands, but removing the wheels would probably be good. What works reasonably?
bluski
Re: Trailer security
Postby les45 » Mon Nov 14, 2016 7:14 am
I wrap a chain through my wheel spokes and around the axle but if someone is really bent on taking your trailer they will find a way.
les45
Images: 605
Postby swoody126 » Mon Nov 14, 2016 9:20 am
in addition to what les45 said i use a separate/longer chain wrap'd around a lamp post and put a pad lock thru the hitch lever when i am leaving a trailer in questionable surroundings
separate chains for the wheels & post make it just a hair more difficult/time consuming to escape w/ the prize
thatsa total of 3 locks
MASTER LOCK makes a commercial unit that can usualy be had from ACE HDW, or any good lock shop, keyed alike and they are s'post2 be tougher to cut
you may have to run a drill thru the hitch lever for the lock bail(¿sp?) to pass thru it
not leaving the dolly wheel on the tongue jack makes it harder to get out of tight spaces
removing the license plate will make it more obvious to law enforcement if towed away
and as everyone knows a true thief bent on having your trailer WILL steal it :(
sw
swoody126
Postby PKCSPT » Mon Nov 14, 2016 10:11 am
Locked in our garage when not in use. Otherwise a cable and padlock run through the wheels, frame and a tree if available when camping. Padlock one the hitch. Cable and padlock are supposed to resist being cut.
121172 116946 159644
PKCSPT
Images: 61
Postby djohnsonnv » Mon Nov 14, 2016 12:48 pm
Has anyone used/considered a trailer boot? They lock onto your wheel some even cover the lug nuts. Cities use them to impound vehicles in place so they must have some merit.
https://www.grainger.com/product/39C426 ... 14180012:s
djohnsonnv
Postby swoody126 » Mon Nov 14, 2016 1:07 pm
djohnsonnv wrote:Has anyone used/considered a trailer boot? They lock onto your wheel some even cover the lug nuts. Cities use them to impound vehicles in place so they must have some merit.
VERY EFFECTIVE butt harder to store/carry taking up valuable space whereas chain can be strung out along the wall/edge of the bed w/o affecting sleeping comfort, taking up relatively no space and the weight can be distributed as needed
also, boots will likely have to be bought new at a retail outet and chain can be found at flea mkts & garage sales for le$$ than retail...
sw
swoody126
Postby lfhoward » Mon Nov 14, 2016 1:13 pm
I just got this in my email from eTrailer.com today.
Discreetly track your trailer with these WHRZT! GPS trailer tracking devices.
www.etrailer.com/dept-pg-Trailer_GPS-pm-WHRZT.aspx
Breakaway and junction box lid styles hide tracking device on your trailer to track trailers in your fleet or ensure that your stolen trailer doesn't get far.
Has anyone installed something like that before?
lfhoward
Postby bluski » Mon Nov 14, 2016 2:15 pm
OK. Some really good ideas here My trailer has the spoke-type rims, so the chain/axle thing will be a really good start. Anything to up the degree of difficulty will help. Thanks for the ideas.
bluski
Postby lrrowe » Mon Nov 14, 2016 9:29 pm
Type "trailer security" in the top right search box and see many previous posts on this topic.
Bob
lrrowe
Images: 439
Postby absolutsnwbrdr » Tue Nov 15, 2016 9:03 am
lfhoward wrote:I just got this in my email from eTrailer.com today.
http://www.etrailer.com/dept-pg-Trailer ... WHRZT.aspx
Looks like that would definitely work. First year subscription is free, $120/yr after that.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby QueticoBill » Tue Nov 15, 2016 9:12 am
Could look at Spot Trace https://www.findmespot.com/en/index.php?cid=128 $50 right now plus $100/yr subscription.
QB
QueticoBill
Images: 22
Postby TimC » Tue Nov 15, 2016 10:38 am
If you won't have to move the trailer on a short notice I suggest putting it on jack stands, blocks, whatever is secure, and removing the wheels. It won't go anywhere. I know this is more of a storage method to secure the trailer. If you are concerned about camping season security you might want to lean toward the other folk's suggestions. Wheel removal will give you some time to research the other methods.
Tim
Niagara, WI
TimC
Images: 736
Postby DrCrash » Tue Nov 15, 2016 8:20 pm
Removable tongue .
DrCrash
Images: 51
Postby noseoil » Wed Nov 16, 2016 8:09 am
Tongue lock, alarm system & Itraq tracker. Too close to Mexico where I live......
137905
noseoil
Images: 669
Postby DrCrash » Wed Nov 16, 2016 1:52 pm
DrCrash
Images: 51
