Does anyone know what type of teardrop this is?
Re: Does anyone know what type of teardrop this is?
Postby dmdc411 » Wed Dec 21, 2016 8:27 pm
johny_swindle , I don't see why not. But give the floor decent support. If you build up the side walls, run a 1 x 4 the entire length at the bottom so the overhang has decent support. If you use plywood for the walls, you should be good.
I followed the drawings sort of closely. Didn't stray to far off.
dmdc411
Postby johnny_swindle » Thu Dec 22, 2016 9:47 am
dmdc411 wrote:johny_swindle , I don't see why not. But give the floor decent support. If you build up the side walls, run a 1 x 4 the entire length at the bottom so the overhang has decent support. If you use plywood for the walls, you should be good.
Thanks...
Sent from my SM-G935V
johnny_swindle
