What size wire are you guys using to operate your interior/exterior of trailer 12 volt LED lights and 12 volt cigarette lighter sockets (for power source needs) ?
Not asking about brake/turn light wire size.
mustangcats wrote:I used 12 gauge throughout my trailer. From the converter to the battery I used 8 gauge. No point in using a thinner wire that may not handle the load.
bdosborn wrote:
That's the sure fire way to do it, assuming none of your loads are over 20A. A #12 wire is good for 20A and a teardrop isn't big enough for voltage drop to be an issue. A #8 is good for 40A so you should good to go unless you have an inverter.
yrock87 wrote:I just realized you asked about the cigarette outlet too. I used 10 gauge for that one. I wanted to be able to pull 30 amps.
I used 10 guage or 18 guage for everything in my trailer. I have a single circuit for cabin lights, a separate circuit for kitchen lights, a circuit for the fantastic and a circuit each for cigarette outlets in the cabin and galley. 10 gauge for the outlets and 18 gauge for everything else. currently 5 am fuses for the lights and 20 amp fuses for the outlets.
To me, using wire that is bigger than in needs to be is A. wasteful, especially when you have a "right size" on hand. but more importantly it is B. harder to run. 10 gauge wire starts to get to be a bit of a pain in small confines.
dancam wrote:yrock87 wrote:I just realized you asked about the cigarette outlet too. I used 10 gauge for that one. I wanted to be able to pull 30 amps.
Do you have a link to what cigarette outlet you bought? Most i have found are rated to a max of 15amps and will not handle even that for more than 10min or so. Their sort of rated for 15amps for as long as it takes to heat up a cigerette lighter... 30amps through one would take a well built outlet.
yrock87 wrote:dancam wrote:yrock87 wrote:I just realized you asked about the cigarette outlet too. I used 10 gauge for that one. I wanted to be able to pull 30 amps.
key word being "wanted". I ended up with a 20 amp outlet from amazon. not sure which one, but here were several. I ran the wire expecting to be able to push 30 amps, then found that cig outlets top out at 20. I also found that most 12 volt appliances top out at 15 amp fuses with 12-13 amp draw. I planned 30 amps expecting hair dryers and such to draw 20+, but they draw 12-13...
