24 ga.steel sheet on rool / coll in CA. Found
Postby saywhatthat » Mon Feb 27, 2017 1:44 pm
With this new style of top modular fiberglass. I believe any nob can do a shell in five days are less.
The 24 ga.steel sheet. it is .05 kilograms / one pound per SQ foot. What I have is 46 inch wide by 120 inches long.no coating
I can make up the room to have 48 inches high in the pod with top modular fiberglass and bottom skirting.
The sheet of steel came from a place that roll their own metal roofs
It has no pant on it raw.
I like to find a place that has color roofing for metal buildings.
That would save a lot of time.
Dose anyone know of a place that may have this metal on a roll/ coll in the bay area of Calif.
I would drive up to 300 mi to pick up.
That be faster than priming painting.Paint never cures when you want it done fast
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Re: 24 ga.steel sheet on rool / coll in CA. Found
Postby saywhatthat » Wed Mar 01, 2017 9:46 pm
Found 26ga 4-by-10 only price $39.00 USA
24 ga 4 by 10 price $ 54.00 USA
Paint is baked on . Good for 45 years if used on a roof.
Also had a stronger foam than you will receive from Home depot at 56 Myrick Street
Ellsworth, ME . for $16.00 USA.
Any big roofing co can order.
I am to receive two sheets of red .and special order .A sheet that has the same look of new one cent piece.
The steel with foam is a little heaver than .32 Alum. and foam.
may take two weeks to receive for the special order
saywhatthat
Images: 135
Postby saywhatthat » Thu Mar 16, 2017 9:06 pm
What I found was MS Colorfast45 steel roofing comes in 48-by-120 inches
http://www.metalsales.us.com/agricultur ... Ms78THLeIo
http://www.metalsales.us.com/agricultur ... Ms86THLeIo
Received today. There’s 7 trailers been built using the D.I.Y. rail top with the tab..
I have preformed two outer rings using the manufacturer trailTop fiberglass modular trailer building components
Using the cut and hinge. trailTop fiberglass modular building components are 120 inches long. Too cut,bend. lay the fiberglass on the joints under 90 minutes .The home made rail-top components used on other Seven trailer's where bigger on the side wall and top .I know the side will be faster with trailTop fiberglass modular . Just cut close and glue drop.
saywhatthat
Images: 135
Postby saywhatthat » Sat Mar 25, 2017 9:55 pm
Some thoughts on using steel sheets. Weight the manufacture info was .6 pounds per square foot. Found it to be .9 pounds per square foot. Must be all the coating. If I use the molded fiberglass with 1.5 mat 7oz woven then one more of 1.5 mat is .4 pounds per square foot. But when the windows and doors are cut out that will reduce some skin weight.
saywhatthat
Images: 135
