Hog Wild wrote:Should I move my axel back 4 to 6 inches on my NT 5x8 trailer before my build is started. I'm looking at building the Simple or Rimple.
I had a good load of stuff on mine when I pulled it to Austin, TX from CT and I moved the axle back to the manufactures position before I towed it. Did you put a load on yours with the axle moved and tow it yet? ...or are you just thinking it will track better? ...because I've thought the same thing. Not criticizing, just curious if the thought of better tracking has been tested/proven.QueticoBill wrote:...Also believe it tracks better with axle moved and tongue extended.
kramergwt wrote:I had a good load of stuff on mine when I pulled it to Austin, TX from CT and I moved the axle back to the manufactures position before I towed it. Did you put a load on yours with the axle moved and tow it yet? ...or are you just thinking it will track better? ...because I've thought the same thing. Not criticizing, just curious if the thought of better tracking has been tested/proven.QueticoBill wrote:...Also believe it tracks better with axle moved and tongue extended.
