les45 wrote:Here are a few tips that I have developed from experience over the years:
1. Practice backing your trailer if you haven't done a lot of it already.
2. Put together a "trailer tool box" with all the tools that you might need for any emergency.
3. Purchase electrical adapters that will let you use any of the outlets on the park power pole.
4. With the electrical adapters, take a circuit checker (simple plug in type) to make sure power sources are safe/correct.
5. Chop some kindling and take it in a bucket (don't depend on finding enough at the campsite). Also some newspapers and lighters for starters.
6. Purchase a small military type folding shovel (I've had to dig a hole to get my tongue jack to swing down).
7. Buy an entire spare hub rather than just spare bearings (much easier to install on the side of the road if you ever have to).
8. Decide how you will secure your trailer while you are away from your campsite (chains, locks, etc.)
9. Plan your meals and how you will keep your food cold.
10. Take a tarp and some spare rope (sooner or later you will need it).
11. Buy a small fire extinguisher and keep it in an accessible location (I keep mine in the TV).
Hope these help.
-Will be done extensively over the next week
-Great call
-done
-done
-i have so much scrap from the build that the table saw and miter saw is going to be chopping me up some great expensive kindling
-done
-I bought 2 just in case
-So i have one of those coupler locks and will also have a wheel lock, the doors are prefab with nice deadbolts and the hatch has swing locks on each side
-coleman steel belted will travel with me in the car but fits in my galley, also have a 20 Grizly and a 20 Yeti cooler at my disposal
100ft paracord and 2 6x8 tarps
-done
Hope these help.
DaBearSox wrote:Got her hooked up today and took a few laps around the block. Seems like the ball is too low. One wheel is actually on the curb so it doesn't look as bad there but was pretty jerky over bumps and felt the weight on the rear of the car. I can't even lower the coupler onto the ball with the jack. So think I need to get a little higher ball mount.
Sent from my VS986 using Tapatalk
DaBearSox wrote:Bought an adjustable mount today and that did the trick. Took her out on the highway and pulled very well. No sway what so ever and the CX-5 did a nice job pulling her. She shakes (up and down) a little bit at lower speed but then it stops when I am at 45+ so I am wondering if that will be rectified when I have her all loaded up.
DaBearSox wrote:What's the best way to store spare hubs? I cleaned all the Chinese gunk out of my replacements and repacked the rear bearings and installed a new seal. I will repack the fronts should I just keep those in a separate baggy or put in the hub and cover with dust cap?
