neglected TT,our home for awhile (w/blackwater problem)
Re: neglected TT,our home for awhile (w/blackwater problem)
Postby jondbar628 » Sun Dec 10, 2017 12:58 am
Working on It......INRE "only time will tell if I can"............In the words of Red Green, "hang in there men - remember, we're all in this together" (more or mostly less accurate quote)...........jd
jondbar628
Postby working on it » Sun Dec 10, 2017 10:40 am
working on it wrote: from another thread... when we emptied the old house, we moved the wireless router into my 3-bay steel garage, just behind the trailer. Anytime we needed to use wifi on our phones (and later on our laptops, after we retrieved them from a storage pod), we had to open the garage door to improve our connection. That wasn't good, as we had furniture packed in the garage, that would get wet if it was raining, and we also needed to keep it closed when the dogs were loose in the compound (hazardous chemicals in the garage).[*]Once we had electricity hooked up in the new house, I had AT&T move the router back inside, into my new corner office/dayroom, and out of the metal "Faraday cage" garage. Immediately, my laptop in the trailer had a much better connection, and my new Samsung S7 too, though it still loses connections periodically. When using my devices, I sit at the trailer's dinette, where the streetside wall, refrigerator, and water heater block direct wireless contact with the router (which I can see thru the house window if I peer out the trailer window over the sink, a mere 65 ft. away). So, I just bought a wifi range extender (TP-Link AC1200) from Amazon, and I'll pair it up with the router, then put it in the trailer on the nightstand, where it will have a clear line-of-sight with the router in the house. It should help, if only for a short while....
  • I received it yesterday, and set it up after my back started giving out when moving the fill dirt. It took me three attempts to get it to link up with my router, using the WPS button on the router, and the RE button on the extender. Then, after pairing them, I took the extender to the trailer, set it up on the nightstand where it had only the blinds & window glass between it and the router in the house (blinds and window glass there, also), and not the aluminum skin.
  • My S7 phone immediately had a better wifi connection, as shown by a Meteor app speed test. where it previously only had marginal upload and download speeds, now they rate "awesome" or "very good" on the tests. Even though this is a just a temporary fix for my trailer stay, when I move it into the house, I'll put it in the central living room to make wifi reception stronger on the other end of the house. My next electronics purchase will be an AT&T Microcell unit, to get better phone reception (we only get one or two bars on our phones, and we've done away with our landline).
    range extender TP-Link AC 1200 (RE380D).png (331.98 KiB) Viewed 453 times
  • 2013 HHRv,"squareback/simple" TTT, semi-offroad? 4x8, 2000+ lbs travel weight
  • featuring:
    • 3500 lb Dexter axle,
    • 27x8.5-14LT tires,
    • LED lighting,
    • A/C & heat,Optima AGM battery,
    • extended-run 2500w generator,
    • Coleman dual-fuel stove & lantern
  • 147697148333125895
  • 148599148106
working on it
Images: 427
Postby working on it » Sun Dec 10, 2017 7:25 pm
  • Propane gas leak detector. Good or bad, I don't know, but when it started sounding off, I turned off the gas and emptied the trailer of dogs. Even after 15 minutes, with no gas on, the door and windows open, and a fan blowing out the door, it was still sounding off. I couldn't reset or mute it, so I disconnected it, took it out to my truck, where I hooked it to the battery (12vdc sensor). It still was going off, 30 minutes later. Guess it went bad, seven years after the "replace date" printed on it. But, fearful of a gas explosion, I left the gas shut off, and still thought I smelled gas anyway, even when I went into the new house, which is all-electric...my imagination gets the best of me, again. I ordered a replacement sensor, to be here in two days; until then, no hot water in the trailer...just another incentive to get the fence up, faster.
    RV Propane Leak Detector.JPG (90.08 KiB) Viewed 409 times
    should've replaced the old one in 2010
P.S., 12-12-2017 The leak detector has been replaced, and the gas turned back on; problem solved. Sure glad it was the sensor, and not an actual propane leak.
Last edited by working on it on Sun Dec 17, 2017 10:04 pm, edited 1 time in total.
  • featuring:
    • LED lighting,
  • 148599148106
working on it
Images: 427
Postby working on it » Sat Dec 16, 2017 10:21 pm
  • I hope this is the last post I will make from this travel trailer...at least on this thread, and as my residence. Today, with help from my wife, I put up a 5 ft high wire fence to replace the back and side yards' fencing I tore down in September, to make room for the new house to be installed. Now, I can let the dogs out of the "dog pound" fenced area in my driveway, and back into the yards next to the house. My wife has the interior almost dog-proof (with baby-gates, and some Ikea floor shelving units to block dogs from the carpeted areas), so they can move to the house from the trailer, and so can I.
  • I barely finished the initial assembly of the fence (adjustments and tightening will come later) when it started raining, It has been raining hard for hours now, and that may delay the move to the house, at least until proper mats are put down, but that will be by tomorrow night. I just hope the rain will not loosen the T-posts I used on the sandy loam side, but it will just make the posts firmer on the clay side, after it dries. So, I will be in the house for Christmas, after all.
  • featuring:
    • LED lighting,
  • 148599148106
working on it
Images: 427
Postby GPW » Sun Dec 17, 2017 5:45 am
The light at the end of the tunnel !!! :thumbsup: Merry Christmas …. !!!
Images: 543
Postby pchast » Sun Dec 17, 2017 9:21 pm
Have a Happy Holiday. :thumbsup:
pchast
Images: 96
Postby working on it » Sun Dec 17, 2017 10:41 pm
  • As promised. I moved myself and the dogs into the house today. Everything is suitably arranged for them, so they have plenty of room to roam, and two of them to sleep in my office, while three dogs will be in the master bedroom with us, at night. I've got most of my personal stuff unpacked, and 3/4 of my clothes hanging in my office closet (she totally filled the walk-in closet with her clothes), and will start arranging it better tomorrow.
  • My rushed work to spread the select fill into areas behind the fence, the erecting of the fence, and moving my stuff int the house has really worked me over. My hands and fingers are swollen, my legs/knees are cramping up, and my shoulders and chest are aching from driving the T-posts into hard ground. I also might have a separated right shoulder (a recurring problem), and a patch of poison ivy rash has re-appeared on my right chest/back/underarm, for no apparent reason. But, at least I get to sleep in a comfortable bed tonight, after 2.25 months in the trailer.
  • This might be my last post on this subject matter. I started it as a sort of "build journal", after failing to do one on my squareback TTT project. I was intending to post a few items I had concern about, to solicit advice/expert opinions from forum members that may have had similar projects/experiences before me. It turned out to be a project report, or blog, with all aspects covered, whether positive or negative, and a running log of what can go wrong while few went right. I hope that anyone with a similar project coming up, can benefit from my chronicle.
  • featuring:
    • LED lighting,
  • 148599148106
working on it
Images: 427
Postby working on it » Mon Dec 18, 2017 8:24 am
working on it wrote:... My hands and fingers are swollen, my legs/knees are cramping up, and my shoulders and chest are aching from driving the T-posts into hard ground. I also might have a separated right shoulder (a recurring problem), and a patch of poison ivy rash has re-appeared on my right chest/back/underarm, for no apparent reason. But, at least I get to sleep in a comfortable bed tonight....
  • After I posted the above, I remembered that my father-in-law had a similar rash, but not from poison ivy, but from shingles. I never thought I would get it, but it makes more sense than poison ivy where I never had it before (I do have a recurrent rash on my left arm, from 10 years ago). Besides, there is no foliage of any kind in my front yards, so I couldn't get it - it is my great nemesis, after getting it a coupla times each year, though-.
  • My rash is a band from front-to-back, and it looks the same as his did, and the pictures on the internet, so maybe I've got it (it itches pretty bad, but not as bad as poison ivy). I had mild chickenpox after receiving the vaccine as a kid, so it's a possibility that I have shingles. At 67, I guess I was a likely candidate. Hope it goes away soon. I'll only go to the doctor if it gets worse; when I had chickenpox, I recovered in less than a week, while friends at school still had it two weeks later, as best I can recall, 60 years later.
  • P.S. the comfortable bed didn't help...I couldn't sleep in any position. The leg cramps were the worst. Like I've stated before, this house project is likely to finish me, even at this final stage of moving in.
  • featuring:
    • LED lighting,
  • 148599148106
working on it
Images: 427
Postby working on it » Tue Dec 19, 2017 9:07 pm
working on it wrote:...My rash is a band from front-to-back, and it looks the same as his did, and the pictures on the internet, so maybe I've got it (it itches pretty bad, but not as bad as poison ivy). I had mild chickenpox after receiving the vaccine as a kid, so it's a possibility that I have shingles. At 67, I guess I was a likely candidate. Hope it goes away soon. I'll only go to the doctor if it gets worse....
It did get worse, much worse, after my last post. First, I became extremely chilled, but feverish (thermometer still remains packed away, somewhere), and went to bed after my wife got home. I wore three shirts, and used two blankets, but still was frozen. About 10pm, I woke up, with severe back and leg pains, a migraine, and was dizzy (not vertigo). An hour later, I felt better, and warmed up, and returned to bed. About the rash...when I was chilled I didn't notice it much, but when I awoke this morning, it burned like fire all day. My wife insisted I go to my healthcare group's after-hours clinic, after she noted that the rash had doubled in coverage overnight. The doctor took one look at it, and wrote me prescriptions to treat SHINGLES. And yes, it actually burns/itches worse than poison ivy, which I presumed was the ultimate rash.
  • featuring:
    • LED lighting,
  • 148599148106
working on it
Images: 427
Postby Socal Tom » Tue Dec 19, 2017 9:44 pm
The chicken pox virus hibernates in your nerve endings, when under enough stress it breaks out. Since it busts open your nerve endings it can be very painful. The itching is due to skin stretching as it tries to heal. You are now contagious for chicken pox. So stay away from the unvaccinated and folks with weak immune systems.
Socal Tom
Images: 9
Postby working on it » Tue Dec 19, 2017 10:53 pm
Looks like no Christmas at the in-laws this year; there will be three infants, six under 10 years, six millennials (one pregnant), my 50-ish wife and sister, and the elderly parents. As far as I know, only the father-in-law has had shingles and vaccination. The doctor said that only direct contact with the rash can infect, but I don't want to take a chance becoming a "Typhoid Mary" with the shingles/chickenpox virus.
  • featuring:
    • LED lighting,
  • 148599148106
working on it
Images: 427
Postby Socal Tom » Wed Dec 20, 2017 3:34 am
Most kids get a chicken pox vaccine, and have since 1995. The first shot is st around 12 to 15 months. So ask them if the have been vaccinated
Socal Tom
Images: 9
Postby Lesbest » Wed Dec 27, 2017 8:42 pm
Shingles are aggravated by stress. When I had mine the Dr. told me no action movies, no Springer type tv, no CARTOONS (What). Relaxing music, light reading, etc. If they get too bad they can last for months.....I followed his advice and in 3 1/2 weeks they were gone, pain was minimal. Mine felt like I was being stabbed in the back, the rash appeared the next day. When your healed don't bother with the vaccine.....you have enough anti-bodies to last till the last rodeo. Hope your feeling better and have a happy New Year.
Hope this helps, Les
Music is like chocolate.......you can't really enjoy it unless the rappers are gone.
Lesbest
Images: 7
Postby working on it » Thu Dec 28, 2017 1:33 pm
  • I'm retired, so my stress level is much less than when working, but the last 5 months have been very stressful, just from this house thing. I've been more relaxed the last week or so, since I finally moved myself and the dogs into the new house, and have had no major problems lately, so that helps. But, having really over-worked myself,
    working on it wrote:...My rushed work to spread the select fill into areas behind the fence, the erecting of the fence, and moving my stuff into the house has really worked me over. My hands and fingers are swollen, my legs/knees are cramping up, and my shoulders and chest are aching from driving the T-posts into hard ground. I also might have a separated right shoulder (a recurring problem), and a patch of poison ivy rash has re-appeared on my right chest/back/underarm, for no apparent reason....
    I guess it triggered the shingles outbreak (not poison ivy, as my wife had guessed), and now the shingles are lingering on longer than the Dr. said. I probably will have to refill the prescription for the antibiotic, and see if I can increase the dosage of the shingle-specific pain-killer (Gabapentin).
  • The shingle blisters have scabbed-over, but don't seem to want to go away. And, there are three very sensitive and painful areas that hurt all the time (causing me stress, and problems sleeping). They bother me more than when I first got them, so I'm worried that they may persist for months (I hope not...spring/summertime activities will be curtailed, if so).
    Shingles pain...forever..JPG (82.01 KiB) Viewed 94 times
  • If I have this, long-term, at least I'm getting side-benefits in other ways, from using the Gabapentin painkiller. It has reduced my sciatic nerve pain, made my knees less painful, and made my restless-leg syndrome go away. Perhaps, having shingles may be a blessing, but a painful one at that.
  • featuring:
    • LED lighting,
  • 148599148106
working on it
Images: 427
Postby working on it » Wed Jan 10, 2018 10:54 am
Lesbest wrote:Shingles are aggravated by stress. When I had mine the Dr. told me no action movies, no Springer type tv, no CARTOONS (What). Relaxing music, light reading, etc. If they get too bad they can last for months.....I followed his advice and in 3 1/2 weeks they were gone, pain was minimal. Mine felt like I was being stabbed in the back, the rash appeared the next day. When your healed don't bother with the vaccine.....you have enough anti-bodies to last till the last rodeo. Hope your feeling better and have a happy New Year.
  • UPDATE, concerning the SHINGLES situation: Day 25, since the rash appeared, and the itch/pain began. The active virus has come and gone, leaving discolored skin spots behind, where the scabs were. Constant burning/itching from those areas; believe it or not, it grows worse every day. I've tried to relax, and haven't resumed working on
    • (1) closing out the trailer (cleaning it after 3+ months' occupancy by humans and dogs), dumping the blackwater tank for the final time, and replacing the tire that had the valve stem blowout. I also need to move the trailer back to its' storage spot, in my yard/car paddock, so I can get my Chevelle out (my neighbor has a BMW X5 to trade, and will also re-wire my garage - upgrading the service to 60 amps, in exchange-; a good deal for him, as the Chevelle is worth much more, but I want him to use it, as I intended, instead of rotting in my garage)
    • (2) finishing the fence installation, that I hurriedly erected , triggering my shingles outbreak- I presume, from the stressful overwork
    • (3) finishing the unpacking, and assembly/arranging of the spare bedroom and my wife's office
  • In this downtime, I have been sitting in my room/office, just web-browsing and watching movies and videos, trying not to move my right arm much (the most painful and bothersome area is on my right inner-upper arm and armpit), trying to follow Lesbest's advice. I called my primary care doctor, and he said to keep taking the Gabapentin, and come see him if the pain persists after the pills are gone. I am really concerned, so I'm making an appointment for Thursday if possible. I advise everyone to get a shingles shot, and not take a chance like I did.
  • featuring:
    • LED lighting,
  • 148599148106
working on it
Images: 427
