Prepping the trailer
Postby Socal Tom » Fri Sep 15, 2017 9:28 am
It may be premature for some but those of you that used your trailer and or camping supplies to help get through the recent storms, is there anything special you did to prepare your rig? Any thing you wish you did?
Full disclosure- I've started a youtube channel, and I hope eventually to get enough views/subscribers to pay for a camping trip. I thought "Prepping your camper" could be a timely topic. ( FWIW I'm up to 10 subscribers and I'm only related to 5 of them!) :R
Socal Tom
Re: Prepping the trailer
Postby friz » Fri Sep 15, 2017 11:31 am
Fill my water jug and a cooler and I'm ready to go.
Sent from my SM-G900V using Tapatalk
The "Sin Bin"
150133
friz
Postby katebatangan » Fri Sep 22, 2017 6:03 am
Love this topic! Hopefully you'll get some great responses
Sent from my SM-G930T using Tapatalk
katebatangan
Postby les45 » Fri Sep 22, 2017 6:48 am
I wired up a DC plug-in outlet in order to use my teardrop's battery to charge iphones and ipads. I had previously used only the AC outlets to charge these items while actually camping. Also plugged into house power several days ahead of time to make sure battery was fully charged. Later I fabricated permanent DC/USB outlets inside the camper.
Of course the propane camp stove and battery powered LED lanterns got lots of use during the power outage.
les45
Images: 605
Postby flboy » Fri Sep 22, 2017 8:07 am
les45 wrote:I wired up a DC plug-in outlet in order to use my teardrop's battery to charge iphones and ipads. I had previously used only the AC outlets to charge these items while actually camping. Also plugged into house power several days ahead of time to make sure battery was fully charged. Later I fabricated permanent DC/USB outlets inside the camper.
I filled the tanks with water, made sure I had full propane, and being HAM operator, I loaded all the radio gear and had food ready to throw in. I didn't evacuate this time, but made sure the trailer would not blow away. Without power and potentially a destroyed home roof, the CTC also would make a great place to stay on property while we make repairs. If both the home and CTC were severely damaged, then, well, it is time to break out the tent. LoL
The CTC has a 500w solar generator and Inverter on board, so it is also a good backup if fuel runs out for the generator. Always will have basic power needs covered until stability restored.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby tony.latham » Fri Sep 22, 2017 10:09 am
The storm was horrible. I took this two days ago during the height of it. It was brutal... I threw in an extra down comforter... Where the hell is Indian Summer?
Postby KennethW » Fri Sep 22, 2017 4:59 pm
I live in Minnesota. We don't bug out. But if I did. I would have 4 good blankets. Cover with as many as required. Sleep on top of the rest. My TD is a foamy with a 2' x 5" solar collector. That is enough to power 2 CPAP's, the fan,tv,and led lights. So power is taken care of. I use a white gas stove for cooking. So If I was to bug out. I would just made sure the kitchen stuff is in the TD, pick up 2 cases of water, ice? and some food. No need for shore power.
KennethW
Images: 82
Postby Socal Tom » Sun Sep 24, 2017 8:54 am
Finally posted my “prepping” video. https://youtu.be/u_Tx6blpglk
Socal Tom
Postby Vedette » Sun Sep 24, 2017 11:51 am
Hi Tony
Just one week before that picture, we were in Idaho floating down the Snake River in Hells Canyon.
Air Temps were in the mid 80s and water was 72 degrees. :roll:
We must have got out of there just in time???? :thinking:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby tony.latham » Sun Sep 24, 2017 12:11 pm
Vedette wrote:Hi Tony
Good Roads
Brian & Sandi
I think you did. I saw lots of float boats coming through "River City" during this stormy weather and wasn't jealous.
I assume your Hell's Canyon trip was great!
T
Postby Shadow Catcher » Sun Sep 24, 2017 7:10 pm
We live in an area not likely to have serious problems, NW Ohio. However Compass Rose is set up for serious boondocking and always has bedding and some food. Solar powers Radio, XM, weather radio, charges cell phones, laptop, battery charger for flashlights refrigerator... Water filters can take water from a lake or stream and make it potable.
My meds are a 90day supply.
I am thinking of buying a case or two of MRE's.
Tow vehicle a Subaru Outback has Micheline all weather tires, and would be gassed up and ready to go.
I grew up tenting and Nancy and I did some wilderness canoe camping, everything went with is an 18'4" Madriver canoe. The teardrop has more room :)
