I might have a solution for you, not a conventional one for teardrops, but it has worked for my application: from another threaddancam wrote:So i made a mistake and hung my one door too low. I cant exactly put the screws for the hinges in 1/8th higher. So what would be your suggestions for a different sealing method? Or somehow moving the door?
I neglected to point out that my solid 3/4" plywood doors are tightly sealed by the automotive seals ('67-'72 Chevy truck doorseals, cut and trimmed to fit) on top & sides, and the door bottom is forced over the aluminum threshold, without a rubber seal, so tightly (so tightly that I use a kickplate to cover the spot on the door, where I use my knee to forcibly seal it), there is no possible water intrusion point...I made sure to seal the end-grain on the door, and re-seal it with more polyurethane each year. The door sweep is just a safeguard against wind-driven rain, and deters surface-tension from directing water to the threshold area. with my bad knees, I probably shouldn't knee my doors shutworking on it wrote:QueticoBill wrote:Do you think the door bottom can be too low? This is of course can be constrained by the door height, but if that is not set, what are the negatives of it being lower, particularly home built doors?
- The OP was asking about door height using pre-made Challenger doors, which I assume come mounted in a full perimeter frame. With that in mind, there would have to be a wall surface of sufficient height above the trailer frame to bolt/screw the doorframe to. That would limit how low the door can be. In QueticoBill's case, and the same goes for my trailer, the doors can go lower, either resting on the trailer frame (I assume using a water-resistant threshold) or at least a door sweep, to deter water intrusion. A standard rubber weatherstrip wouldn't work, in a small TD or TTT, because of contact with an occupant's derriere, when entering or exiting thru a short door (especially in a 4x8). Larger door sizes, in a standy or cargo conversion, would pose no need to enter while sitting down, so a full perimeter doorseal could be used.
- doors go to wall bottom, 3/4" above frame (resting on floor)
- pieces used in lieu of full perimeter doorseal
- upper door uses rubber seal not possible at floor
John61CT wrote:Into steel? Brazing the holes maybe easier than cutting in a new piece.
Then again, there are amazing adhesives these days, try 3M VHB tape?
working on it wrote:I might have a solution for you, not a conventional one for teardrops, but it has worked for my application: from another threaddancam wrote:So i made a mistake and hung my one door too low. I cant exactly put the screws for the hinges in 1/8th higher. So what would be your suggestions for a different sealing method? Or somehow moving the door?
http://www.tnttt.com/viewtopic.php?f=21&t=68383I neglected to point out that my solid 3/4" plywood doors are tightly sealed by the automotive seals ('67-'72 Chevy truck doorseals, cut and trimmed to fit) on top & sides, and the door bottom is forced over the aluminum threshold, without a rubber seal, so tightly (so tightly that I use a kickplate to cover the spot on the door, where I use my knee to forcibly seal it), there is no possible water intrusion point...I made sure to seal the end-grain on the door, and re-seal it with more polyurethane each year. The door sweep is just a safeguard against wind-driven rain, and deters surface-tension from directing water to the threshold area. with my bad knees, I probably shouldn't knee my doors shutworking on it wrote:QueticoBill wrote:Do you think the door bottom can be too low? This is of course can be constrained by the door height, but if that is not set, what are the negatives of it being lower, particularly home built doors?
featherliteCT1 wrote:Could you remove the hinge, drill new holes in the hinge for the door side of the hinge, raise the door, and screw the hinge back onto the door so the the new holes are far enough away from the old holes to get a good bite?
pchast wrote:How did you build the doors? You can move the hinges depending
on how large the support is for them. You can always fill the screw
holes and drill new ones if needed too...
bc toys wrote:get some golf tees and glue them in the old holes hammer them in tight let dry cut off excess and raise door and resrew it where you want it to be
Oh, i see. When you said that i went to look at the door and realized that while i had enough room to do that when the door was closed my overhang saggs a bit and the door might rub it when open if i did that. :/ this wouod have been the best plan though.Nodrog wrote:Hey Dancam- I think what the poster above is suggesting is to move the hinges on the frame or wall and the door both, everything gets new holes. Move both a cm but put the door in the right place when you rehang it! Will that work or what did I miss? You must be getting the trailer done? Later...Nodrog
Yeah, not the best, but hopefully it worksJohn61CT wrote:OK didn't get wood frame, just cut out the segment and glue a filler block.
Screwing into the **edge** of plywood?
Doesn't sound stable long-term to me?
I really didnt want to. I was scared of it chipping and didnt want to reseal it in fear of it not getting completely sealed. Its what i ended up doing though. Chipped some massive splinters off so now my nice door is ugly. Sealed the bottom with the mix. Once thats dry i will use wood filler on the spintered areas and then paint it.Woodbutcher wrote:Is there a reason you can't cut an eighth of an inch off the bottom of the door and reseal it?
Lol, its a pop up trailerJiminsav wrote:my question is, why do you have an inner and outer door...you building a Masonic teardrop?
