Northern Tool Trailer hubs
Postby Carl01234 » Fri Jun 15, 2018 7:35 am
I just replaced my axle, hubs and wheels with u tows from northern tool. The lug nuts that came with hub are not long enough for my wheels. I have looked every where for the size of the lug nuts and cant find them. Called Northern tool and they had no idea. Are these standard 1/2 inch 20tpi?
2nd Build 5x10 Benroy Complete! viewtopic.php?f=50&t=70427
Carl01234
Images: 116
Re: Northern Tool Trailer hubs
Postby pchast » Fri Jun 15, 2018 9:28 pm
Pop one out and check with the size testers usually available on any hardware bolt display. :thumbsup:
pchast
Images: 96
Postby JuneBug » Sat Jun 16, 2018 12:24 pm
Somewhere in your city there will be store(s) that specialize in nuts, bolts, screws and fasteners. One store in my city advertises: Projects can get screwy, but don’t go nuts.
I just googled Chattanooga, TN and there is
Atlas Bolt and Supply
Chattanooga Bolt and Screw
Bolts and Nuts Corporation
They will probably be very cheerful helping you sort out what you need.
"The large print giveth; the small print taketh away" Tom Waits
JuneBug
Postby Carl01234 » Mon Jun 18, 2018 7:15 am
Got a call back from Northern Tool. They are standard 1/2 20tpi.
Carl01234
Images: 116
