Immobilize your trailer with a bike lock
Postby djohnsonnv » Thu Jul 05, 2018 6:30 pm
I needed to find a way to lock up a small utility/kayak trailer and found an old bike lock in my garage. Turns out that it easily fits around the leaf spring and through the wheel.
djohnsonnv
Re: Immobilize your trailer with a bike lock
Postby friz » Thu Jul 05, 2018 6:37 pm
I do the same. You have to look close to spot it.Image
Sent from my SM-G930V using Tapatalk
The "Sin Bin"
150133
friz
Postby SunTrekker » Fri Jul 06, 2018 9:55 pm
That is a great idea!
SunTrekker
Postby Modstock » Sat Jul 07, 2018 6:17 pm
Love the "out of the box" idea. Thank you.
Sent from my H1611 using Tapatalk
Modstock
Postby low277 » Sun Jul 08, 2018 8:26 am
That is a good idea!!! Simple is good!!! :thumbsup:
NW Minnesota
low277
Images: 5
Postby 2bits » Tue Jul 10, 2018 6:11 pm
I like that idea!
Friz, I also like the "Sin Bin"! Sounds like a name for the van's back in the 60s and 70s. I had one for a couple of years... "Slot Machine"
Thomas
2bits
2bit Member
Images: 16
Postby ae6black » Wed Jul 11, 2018 11:42 am
I just use a piece of chain and go through the wheel and tie it back up on the frame in plain view secured with a simple lock. Even more than for security, when I am parked on a hill, this would stop the wheels from rolling and my td from rolling into or over any of my neighbors.
Art
ae6black
Images: 19
Postby working on it » Wed Jul 11, 2018 5:45 pm
  • I've used chains/cables with separate locks (usually around a tree, attached to the trailer), coupler-specific locks of several types (I have a welded-steel cube surrounding the Bulldog coupler on my car-hauler; wish I could find a similar one for the Attwood coupler on my TTT), and a few bicycle-lock-types for other things (long shank locks, usually with small diameter legs). I even had a Kryptonite bicycle lock or two, years ago, when I could still ride bike trails. But, my favorite type is probably the cable lock, with its' own lock attached (not a combination lock...they fail quickly, IMO).
  • Regular locks, of most types, are not a challenge to even the most inexperienced thief, and can be broken open with just a pry-bar and/or a BFH. Most coupler locks can be defeated in less than a minute, often quietly, so I don't trust or rely on them entirely. I do trust the welded coupler lock on my car-hauler, but until I found it, I ran a Brinks cable lock thru a rear wheel and around a spring, if I had to detach my truck from it, which seldom happened. On the same note, I seldom detach my truck from my squareback TTT, because the Weight Distributing hitch set-up I adapted to haul it, is very hard to attach/detach (two jacks are needed), so no further locking is necessary. On two or so trips I had, before the WD hitch adaption, I did use a cable lock thru a wheel (modular type, with holes).
  • I currently have three cable locks: two 20+ years-old Brinks (one currently in use, and the other gone missing during our recent home changeover), and a smaller 5+ year-old Masterlock, on my wife's travel trailer spare tire (new, on a new wheel, tempting theft). As the numbers state, I've used them for many things, over many years. I think they are less likely to be broken by hammer or pry-bar, but require a large bolt-cutter, angle grinder, or metal-cutting saw to defeat. And I don't think most people are as likely to try, unlike just giving a simple lock a quick hit or leveraging blow. Again, IMO.
    keyed cable locks.jpg (153.54 KiB) Viewed 360 times
  • After reading this thread for the third time, I decided to start using a cable lock again on my campouts, even if if never leave the campsite, just because. I just now ordered a brand of lock new to me, Onguard, though I've hear of them before, and never used one of their products. I failed to measure the hole diameter of my wheels first, so it may not fit, in which case I'll re-use the Masterlock cable lock, that I have on the wife's trailer spare tire.
    onguard akita cable lock, new.jpg (175.75 KiB) Viewed 360 times
2013 HHRv "squareback/squaredrop", semi-offroad, 4x8 TTT, 2065 lbs
  • *3500 lb Dexter EZ-Lube axle, w/brakes, 3000 lb. springs, & active-progressive bumpstops
  • *27x8.5-14LT all-terrain tires (x 3) *modified Weight Distribution system for single-beam tongue
  • *LED lighting, triple fans, Pioneer stereo *A/C & 110vac heat, Optima AGM, inverter & charger(s)
  • *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill
  • *zinc/stainless steel front racks *96"L x 6"Dia. rooftop fishing rod/reel carrier
156212148599156215
working on it
Images: 449
