OP827 wrote:I personally think that 1/4 skin is an overkill extra weight. All you need is a strong skin attached to foamular. Good quality 1/8" Baltic birch ply covered outside by 1 layer of fiberglass cloth and epoxy and just epoxy coating on inside skin should do a good job. For rigidity, a LOT depends of how thick is the Foamular panel core. 7' feet is a relatively big span for a trailer roof. You may also consider doing some slight curvature in the roof to help with water runoff.
JamesDixonLR wrote:OP827 wrote:I personally think that 1/4 skin is an overkill extra weight. All you need is a strong skin attached to foamular. Good quality 1/8" Baltic birch ply covered outside by 1 layer of fiberglass cloth and epoxy and just epoxy coating on inside skin should do a good job. For rigidity, a LOT depends of how thick is the Foamular panel core. 7' feet is a relatively big span for a trailer roof. You may also consider doing some slight curvature in the roof to help with water runoff.
I like your idea of curvature. At this point, that would require a do over but I will keep it in mind. If I took a sheet of 3/4 plywood and made a few curved spars, I could lay the top plywood over it. The kerf some foamular so that I could bend it and place that between the spars and then the ceiling plywood.
Since the roof is going to be detachable from the rest of the body if I make a mistake with it, or simply change my mind, it won't be as big a project as it might otherwise be.
thanks
