Has anyone ducted a window AC into their trailer?
Postby rebar » Sun Jul 15, 2018 11:31 am
Iv seen a few pictures of window shakers ducted into a trailer, but I'm not finding anyone on a forum who has done this.. I see the company climate right offers a portable unit which looks good. But the reviews aren't the best and it costs 3X more than a good Frigidaire window shaker..
I'm guessing the blower on the window shaker wasn't designed to push air through a round duct.. But has anyone here done this?
Thanks!
97 12 valve 4x4 5 speed
rebar
Re: Has anyone ducted a window AC into their trailer?
Postby me&z » Sun Jul 15, 2018 11:36 am
me&z
Postby rebar » Sun Jul 15, 2018 11:55 am
me&z wrote:Try this thread. viewtopic.php?f=30&t=44561
Perfect!
Thanks me&z !
rebar
Postby Sparksalot » Sun Jul 15, 2018 12:54 pm
I did based on the HVAC hack thread above. I made a removal window insert for the duct connections.
My next step will be to make it so the inlet/outlet airstreams are more separated by either baffles, or just adding connections on opposite sides of the cabin.
152735
Sparksalot
Images: 682
Postby 2bits » Wed Jul 18, 2018 6:03 pm
Here is John Millers from South Central group
Thomas
2bits
2bit Member
Postby 2bits » Wed Jul 18, 2018 6:04 pm
and Brads
Thomas
2bits
2bit Member
Postby rebar » Thu Jul 19, 2018 10:07 am
Sparksalot wrote:I did based on the HVAC hack thread above. I made a removal window insert for the duct connections.
152735
Thanks Sparksalot.. Is it worth cutting holes in your tear drop just to get them separated? I would guess for such a small area your window insert is adequate.
2bits wrote:Here is John Millers from South Central group
2bits wrote:and Brads
Thanks.. Looks like no one had to use a booster fan..
rebar
Postby steve cowan » Thu Jul 19, 2018 8:25 pm
139099
137233
The original controls were removed.A wireless remote thermostat was used.Also,a on/off delay timer was wired in the circuit to cycle the compressor
to prevent icing coil.It is set 6 minutes on/2 minutes off.The coil has never iced up.
steve cowan
Images: 207
