So I'm about to make my plywood corners on my Caveman 13 build.
It's the '73 Caveman camper plans off ebay, but I'm making it longer
Anyways it has rounded corners on the top and my wall studs are 1 x 1.5 actual.
Would luan plywood be suitable for the corner? They have some 1 inch wide luan with a high number of laminated layers in it.
I was also thinking of gluing 2 1/2 inch plywood pieces together and cutting my corners out of that.
Basically looking for advice on what plywood to use that would be 1 inch thick and make a strong corner.
I need to start a build thread!
Sent from my SM-N950U using Tapatalk
