Finally had a chance to get the trailer out into the Polar Vortex. I know there are similar kerosene burning heaters at a lower price but thought actual field use might be of use.
https://youtu.be/9VEBR8fh-Bo
=Cosmo
It does not get hot to the touch due to air flow.
I took measurements and found that is incorrect. It draws enough to drain a trailer in storage for a month.
Cosmo wrote:Tony when I had my heat installed I noticed the battery in the the trailer drained in storage., I read the specs and Propex claimed when the unit is switched off it drew micro volts meaning nothing to worry about. I took measurements and found that is incorrect. It draws enough to drain a trailer in storage for a month. The solution in my case was to add a switch. I turn it off when not in use. The unit has an LED in it that goes out when turned off for verification. Other than that no issues with the heater. I like it more now that I have been in some serious cold. I only used one switch I have 4 extras - if you need one let me know. https://www.amazon.com/gp/product/B076R ... UTF8&psc=1
=Cosmo
