Budget siding/roof options
Postby mattiker » Wed Mar 06, 2019 7:17 pm
Hey there, doing a budget build with 3/4 in plywood. I've read that aluminum sheet metal is a good option for the outside of the trailer, but am coming up empty on where to acquire it. My build is 4'x6'x4" if that helps at all.
Are there more budget friendly options for aluminum or alternatives that work alright (used metal roofing maybe)? Rain is a concern where I live.
Also, is there a minimum thickness that is recommended?
mattiker
Re: Budget siding/roof options
Postby Mr. Lahey » Wed Mar 06, 2019 8:20 pm
Search the forum here for info on poor man's fiberglass or PMF. Very budget friendly and very durable. Roofs, walls, and hatch. Cover the whole camper with it.
Used on many builds here.
My teardrop camper build journal: http://www.tnttt.com/viewtopic.php?f=50&t=64721
Mr. Lahey
Postby tony.latham » Wed Mar 06, 2019 8:44 pm
...but am coming up empty on where to acquire it.
Where are you located?
:thinking:
T
Postby Tomterrific » Wed Mar 06, 2019 8:55 pm
Tradition dictates 1/2" plywood so that saves a little money. You can paint the outside so that saves more. I used white elastomeric roof coating over Revolution ply for my roof and it worked okay. I have an idea for a rustic teardrop made from old cedar fence pickets and a corrugated steel roof that would be super inexpensive.
Tt
Tomterrific
Postby mattiker » Wed Mar 06, 2019 10:19 pm
I'll be sure to look into fiberglass, hadn't really considered that option. I'm located in central Arkansas, reached out to a couple of junk yards and fabrications but haven't heard anything back from the fabrication type places. I'll look into 1/2" as well.
mattiker
Postby tony.latham » Wed Mar 06, 2019 11:01 pm
Postby rjgimp » Fri Mar 08, 2019 2:02 am
mattiker wrote:Hey there, doing a budget build ...
If a budget build is what you're after, I concur with the suggestion of skinning with Poor Man's Fiberglass, which isn't really fiberglass at all but paint impregnated canvas. It is very durable, water resistant (been used in boat construction for decades - any questions?) easily constructed with minimal skills and tools, easily repairable, and very inexpensive. I suggest you do your budget an even bigger favor and trade that plywood in for EPS or XPS foam, which is easier and more forgiving to work with, cheaper than plywood in many parts of the country, and will never rot! Take a stroll through the Foamie section of this site and see what you think. Foam, in combination with PMF as a structural panel, makes a fantastic TD.
-Rob
rjgimp
Images: 7
Postby GPW » Fri Mar 08, 2019 6:13 am
We second what Rob said !!! ^ :thumbsup:
Our Foamie with PMF skin lives outside and is going on it’s sixth year … :D
Postby Kim Armstrong » Sat Mar 09, 2019 11:52 am
You can find aluminum at Mr. Plastic in Little Rock or Great Dane trailers.
Kim Armstrong
Postby twisted lines » Sun Mar 10, 2019 12:10 pm
This post came at the last minute and nudged me, set on painted aluminum siding now thanks :thumbsup:
Now for the 5'6" :? roof
Racking up; And Rapin foam
twisted lines
