12 Volt Cab A/C
12 Volt Cab A/C
Postby jrice4760 » Wed Jun 12, 2019 1:05 pm
Does anyone have any experience using this type of 12 volt A/C system? I did try to search on this site before submitting this question, but nothing of this sort seems to have been discussed.
https://www.alibaba.com/product-detail/ ... 4567oFQRdr
It seems to be used for truck cabs, and perhaps RVs as well.
Full Disclosure: I'm a complete newb :) . I've never built a camper of any kind, much less a teardrop.
Jeff
jrice4760
Re: 12 Volt Cab A/C
Postby GuitarPhotog » Wed Jun 12, 2019 4:39 pm
Even at the minimum rated power (300W), it would run a typical teardrop battery (120Ah) down to zero in a little over 4 hours and at max rated power (3000W) it would kill the battery in 1/2 hour.
Diesel trucks have lots of battery capacity, and often idle the engine to keep the heat/AC running all night.
:beer:
<Chas>
GuitarPhotog
Images: 55
Re: 12 Volt Cab A/C
Postby Socal Tom » Wed Jun 12, 2019 4:44 pm
Looking at the pictures it has an engine drive compressor, so it appears you need to have your engine running to use it.
Socal Tom
Re: 12 Volt Cab A/C
Postby Aguyfromohio » Wed Jun 12, 2019 7:09 pm
When we started our builds I too searched for a low power air conditioner that runs on a 12 volt battery.
It does not exist. We could run through the physics and engineering but instead we can just look at what sells in the marketplace.
If such a unit existed it would be standard equipment on every small boat and small camper - they would sell like hot cakes; every owner wants one. But no boat or RV offers one.
The best we can get is what we see in little manufactured RVs; the smallest window air conditioners that run on 120 VAC tucked into a cabinet, powered by shore power or a generator. The units for the sleeper cabs in big trucks are using the big truck diesel engine’s alternator for power.
Aguyfromohio
Images: 76
Re: 12 Volt Cab A/C
Postby Atomic77 » Wed Jun 12, 2019 11:31 pm
We did a lot of research on this subject... what the Others here have said is 100% correct. Here's our version:
Sent from my SM-N950U using Tapatalk
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Re: 12 Volt Cab A/C
Postby Pinstriper » Thu Jun 13, 2019 8:21 am
Fans and shade are a pretty effective combination, and in really hot conditions, a fan with a mister takes it up another notch. We bought one at Home Depot a few years ago, sits atop a 5 gallon bucket and runs on Ryobi One+ batteries. Best money ever spent.
Grab an extra popup shade for $65 at HFT. Buy two, one for outdoor living space, and one to shade the teardrop. Heck, buy a third.
Let's eat, Grandma !
Let's eat Grandma !
Commas. They save lives.
Pinstriper
Re: 12 Volt Cab A/C
Postby jrice4760 » Thu Jun 13, 2019 9:01 am
I appreciate all the replies. The small, under-counter unit seems to be a good option.
Can anyone tell me about the Dometic unit shown at 2:30 in this video? https://youtu.be/eqE9ZxLB7RU
It seems to be a split unit, and the Conqueror website indicates that it's an option for an additional $3800.00. Seems kinda steep. Also, it doesn't appear on the Dometic website.
Thanks again for indulging a newb.
Jeff
jrice4760
Re: 12 Volt Cab A/C
Postby Atomic77 » Thu Jun 13, 2019 9:31 am
The thing we have adjusted to is, if there is electricity available we will have A/C. If there is no electricity available we have two Coleman fans that run on DC power. I can run them off my battery bank or D size batteries. Seems to work for us.
Michael
The Astroliner
Atomic77
Images: 309
